CODE correction for extract ATTRIBUTE
Message 1 of 26
Dear All,
I am writing a code to extract block ATTRIBUTE into excel file like below. I can load the lisp without any issue. While running in CAD the loop is not completed. And i put something wrong somewhere. but i could not correct that. Could you please anyone correct me and teach me where i put wrong. ?
I have attached my Lisp and CAD block file here.
(defun c:ATTX()
	(setq filePath "c:\\temp\\")
	(setq fileName "P&ID List")
	(setq fileLoc (strcat filePath fileName ".csv"))
	(setq xcelfile(open fileLoc "w"))
	(setq blocks (ssget "_X" '((0 . "INSERT") (8 . "VALVE"))))
	(setq ctr 0)
	(setq len (sslength blocks))
	(write-line (strcat "ValveTag") xcelfile)
	(while (/= ctr len)
		(setq blk (ssname blocks ctr))
		(setq blks (entget blk))
		(setq flag T)
		(while flag
			(setq lArea (entget(entnext(cdr(assoc -1 blks)))))
			(setq attrib1 (cdr(assoc 0 lArea)))
			(if (= attrib1 "ATTRIB")
				(progn
					(setq tagnameArea (cdr(assoc 2 lArea)))
					(if (= tagnameArea "VALVETAG")
						(setq valveTag (cdr (assoc 1 lArea)))
				(setq flag nil)
		(write-line (valveTag) xcelfile)
		(setq ctr (1+ ctr))
	(close xcelfile)
	(princ (strcat " Extraction is complete. " fileName " has been created. "))
	(princ)
Replies (25)
Message 21 of 26
_Tharwat
Come on Alan, please try to change your way of contributing in threads all over forums, copy and paste will keep you in the same level and would embarrass you from time to time with the wrong inputs, try to write routines from scratch all the time to go forward and to enhance your abilities in this domain.
Understanding the mechanism and the return values of codes is a must to write successful codes all the time.
Message 22 of 26
Sorry to disturb you again,
I made an addition in that code you gave. But i have some issue in the output.
This is the code i modified.
(defun c:ATTX ()
	(if
		(and
			;;	ensure that there are block objects on this layer	;;;
			;; Checks if directory exist			;;
			(findfile (setq filePath "c:\\temp"))
			(setq fileLoc (strcat filePath "\\" fileName ".csv"))
			(setq ctr 0)
		(progn
			(write-line (strcat "VALVE NAME,VALVE TAG") xcelfile)
			;; 	while ctr valeu is less than len	;;
			;; 	selection sets are 0 index		;;
			(while (< ctr len)
					(while
						(and
							(null valveList)
							(setq blk (entnext blk))
							(= "ATTRIB" (cdr (assoc 0 (setq enx (entget blk)))))
							(= "ATTRIB" (cdr (assoc 0 (setq enx1 (entget(entnext(cdr (assoc -1 enx))))))))
							(setq vName (entget blk))
						(setq valveTag (cdr (assoc 1 (reverse enx))))
						(setq valveArea (cdr (assoc 1 (reverse enx1))))
						(setq valveList (strcat valveTag " " valveArea))
						(setq valveName (cdr (assoc 2 vName)))
				(write-line (strcat valveName "," valveList) xcelfile)
				(setq ctr (1+ ctr) valveList nil)
			(close xcelfile)
		(princ "\nNo valid block(s) found")
(princ)
The output i am getting is like the below.
But the correct output should be,
Do you have any idea why am getting the wrong info,
I have attached my CAD file also.
Message 23 of 26
pbejse
I made an addition in that code you gave. But i have some issue in the output...
From the looks of it, you are wanting to get the block name and the tag value(s) [ 2 ]
(defun c:ATTX ( / blocks filePath fileName fileLoc bname lst xcelfile ctr len valvetag blk )
  (if
    (and
       (setq blocks (ssget "_X" '((0 . "INSERT")(66 . 1)(8 . "VALVE"))))
	(setq ctr 0 len (sslength blocks))
       (progn
	(while (< ctr len)
	(setq bname (getpropertyvalue blk "BlockTableRecord/Name"))
	    (while (and (setq blk (entnext blk)) (= "ATTRIB" (cdr (assoc 0 (setq enx (entget blk))))))
	        (setq lst
	            (cons
		                lst
  	  (setq lst (reverse lst))
	  (write-line (strcat bname "," (car lst) " " (cadr lst)) xcelfile)
	  (setq ctr (1+ ctr) lst nil)
	(close xcelfile)
	(princ)
Message 24 of 26
Thanks again,
I am getting an error (; error: ADS request error) in the below line
Message 25 of 26
pbejse
@Anonymous wrote:
Thanks again,
That is strange, what Autocad version are you using anyway?
Anyway. change that line to and tell me how it goes.
(setq bname (cdr (assoc 2 (entget blk ))))
Message 26 of 26
Using AutoCAD 2013,
And the new line is working good,
Thanks you
