CODE correction for extract ATTRIBUTE
Message 1 of 26
Dear All,
I am writing a code to extract block ATTRIBUTE into excel file like below. I can load the lisp without any issue. While running in CAD the loop is not completed. And i put something wrong somewhere. but i could not correct that. Could you please anyone correct me and teach me where i put wrong. ?
I have attached my Lisp and CAD block file here.
(defun c:ATTX()
	(setq filePath "c:\\temp\\")
	(setq fileName "P&ID List")
	(setq fileLoc (strcat filePath fileName ".csv"))
	(setq xcelfile(open fileLoc "w"))
	(setq blocks (ssget "_X" '((0 . "INSERT") (8 . "VALVE"))))
	(setq ctr 0)
	(setq len (sslength blocks))
	(write-line (strcat "ValveTag") xcelfile)
	(while (/= ctr len)
		(setq blk (ssname blocks ctr))
		(setq blks (entget blk))
		(setq flag T)
		(while flag
			(setq lArea (entget(entnext(cdr(assoc -1 blks)))))
			(setq attrib1 (cdr(assoc 0 lArea)))
			(if (= attrib1 "ATTRIB")
				(progn
					(setq tagnameArea (cdr(assoc 2 lArea)))
					(if (= tagnameArea "VALVETAG")
						(setq valveTag (cdr (assoc 1 lArea)))
				(setq flag nil)
		(write-line (valveTag) xcelfile)
		(setq ctr (1+ ctr))
	(close xcelfile)
	(princ (strcat " Extraction is complete. " fileName " has been created. "))
	(princ)
Replies (25)
Message 2 of 26
hak_vz
(while (/= ctr len)
replace with
(while (< ctr len)
Miljenko Hatlak
Message 3 of 26
Thanks for your fastest reply,
But i have no luck.
It is still the same model of loading when running the lisp file.
The lisp file is working and its complete the process without writing anything in the excel file. If I put the code like the below.
(while(> ctr len)
Message 4 of 26
hak_vz
OK. Upload  dwg the file with predefined blocks and layers for easier work.
I will check the code to for error.
Miljenko Hatlak
Message 5 of 26
hak_vz
Try this
(defun c:ATTX()
	(cond
		((and (setq f (getfiled "Output .csv file:" (getvar "dwgprefix") "csv" 3)))
			(setq outstring (strcat "\nExtraction is complete. " f " has been created. "))
			(setq xcelfile (open f "w"))
			(setq ctr 0)
			(write-line "ValveTag" xcelfile)
			(while (< ctr len)
			(setq flag T)
			(while flag
					(progn
					(setq flag nil)
			(write-line valveTag xcelfile)
			(setq ctr (1+ ctr))
			(close xcelfile)
			(princ outstring)
	(princ)
Miljenko Hatlak
Message 6 of 26
pbejse
(defun c:ATTX ( / blocks filePath fileName fileLoc xcelfile ctr len valvetag blk )
  (if
    (and
        ;;	ensure that there are block objects on this layer	;;;
       (setq blocks (ssget "_X" '((0 . "INSERT")(66 . 1)(8 . "VALVE"))))
       	;; Checks if directory exist			;;
	(findfile (setq filePath "c:\\temp"))
		fileLoc (strcat filePath "\\" fileName ".csv"))
	(setq ctr 0 len (sslength blocks))
       (progn
	;; 	while ctr valeu is less than len	;;
	;; 	selection sets are 0 index		;;
	(while (< ctr len)
	    (while
	        (and
	            (null valveTag)
	            (setq blk (entnext blk))
	            (= "ATTRIB" (cdr (assoc 0 (setq enx (entget blk)))))
			(setq valveTag (cdr (assoc 1 (reverse enx))))
	  (setq ctr (1+ ctr) valveTag nil)
	(close xcelfile)
    (princ "\nNo valid block(s) found")
	(princ)
Message 7 of 26
_Tharwat
Following your way of coding but you need to localize the variables.
(defun c:ATTX ()
  (setq xcelfile (open fileLoc "w"))
  (if (setq blocks (ssget "_X" '((0 . "INSERT")(66 . 1)(8 . "VALVE"))))
    (progn
      (while (setq blk (ssname blocks (setq len (1- len))))
        (while
          (and (setq blk (entnext blk))
               (/= (cdr (assoc 0 (setq lArea (entget blk)))) "SEQEND")
           (if (= (cdr (assoc 0 lArea)) "ATTRIB")
             (progn
               (setq tagnameArea (cdr (assoc 2 lArea)))
      (close xcelfile)
                     fileName
  (princ)
Message 8 of 26
_Tharwat
What's the function STRCAT for? 😉
Message 9 of 26
_Tharwat
Be careful if the ssget function returns nil, then the program will throw an error and keep the file hanging in the sky without closing. 😉
Message 10 of 26
pbejse
 Bad case of copy and paste is what 😀
Message 11 of 26
hak_vz
I know. But since @Anonymous  is greasing elbows to learn autolisp I would like him to start testing his code and look for potential potholes. That is best way to learn programing, and we all have gone through this.
Miljenko Hatlak
Message 12 of 26
pbejse
Though I agree  with you about learning, but that particular error would be a tough one for a beginner to figure out on their own, would you agree?
Cmon @hak_vz , be nice 😉
Bet money the OP restarted CAD about 5 times by now,
Message 13 of 26
hak_vz
@Anonymous
Your code is not bad but you have to start using testing.
Instead using IF statements try to use COND.
With selection sets there is a catch. When you receive selection set always test for its existence and number of elements inside it.
(setq ss (ssget))
(cond
       ((and ss (> (sslenght ss)0)
        ...... code goes here
Same principle apply when you use function getfiled to select input/output file through system dialog.
If you hit <esc> during file selection file path string will be nill and code will present an error.
(cond
Miljenko Hatlak
Message 14 of 26
_Tharwat
@hak_vz wrote:
@Anonymous
(setq ss (ssget))
(cond
You don't need to check if the sslength of the selection set is more than one as long as the selection set is not equal to nil.
COND can't be BETTER than IF function nor visa versa because that depends on the situation and sometimes on the experience of the user.
Message 15 of 26
hak_vz
@_Tharwat wrote:
@hak_vz wrote:
@Anonymous
Yes, but if you want to have your code bulletproof you have to add it in your code. Once selection set equals null your code will break.
True and false. It is a different story when number of PROGN blocks starts to rise. Cond is than easier to handle.
Miljenko Hatlak
Message 16 of 26
_Tharwat
You got it the wrong way, and this is what I meant based on YOUR cond way,
(cond (ss  ;; this is enough without checking if the length is more than zero.
Also True and False, the number of times you use PROGN is less than the number of statements you might use with COND although that I did not refer to that at all.
Message 17 of 26
Sea-Haven
hak_z and Tharwat My $0.05 when writing code I do
(if (setq ss ....
(progn
hit enter a few times
Then go back in and add code that way know IF is balanced. Same with REPEAT.
It is something I should do more often stopping selection errors and admit to that.
Message 18 of 26
I have tried with the selection set by manual way, its has a proper contents successful.
But only thing the loop is getting issue.
Thanks for the suggestion.
Message 19 of 26
1 st Positive response from your code,
Its running and the excel file is creating successfully.
Thanks for this.
Message 20 of 26
_Tharwat
Thanks for this.
You're welcome anytime.
