Click2XLS AND Text2XLS
adaptacad
Message 1 of 27
adaptacad
Hello guys.
Does anyone have a .LSP with or without the .VLX codes?
or something like that ?
https://www.youtube.com/watch?v=FwW1HIVSOVk
Replies (26)
Message 2 of 27
cadffm
Sure, someone have a function like this, incl. me.
But why do you asking us and why you dont use this tool what you found (cadstudio)?
Sebastian
Message 3 of 27
I use something like that, as a bridge between AutoCAD and Excel I have no idea.
(defun LM:writecsv ( lst csv / des sep )
  (if (setq des (open csv "w"))
    (progn
      (setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (",")))
      (foreach row lst (write-line (LM:lst->csv row sep) des))
      (close des)
      t
(defun LM:lst->csv ( lst sep )
  (if (cdr lst)
    (strcat (LM:csv-addquotes (car lst) sep) sep (LM:lst->csv (cdr lst) sep))
(defun LM:csv-addquotes ( str sep / pos )
  (cond
    ( (wcmatch str (strcat "*[`" sep "\"]*"))
     (setq pos 0)
     (while (setq pos (vl-string-position 34 str pos))
       (setq str (vl-string-subst "\"\"" "\"" str pos)
	     pos (+ pos 2)
     (strcat "\"" str "\"")
    ( str )
(defun C:TxtXLS(/ lst ss i el x fn)
  (setq lst (list) ss (ssget (list (cons 0 "TEXT"))))
  (repeat (setq i (sslength ss))
    (setq x (ssname ss (setq i (1- i))))
    (setq el (entget x))
    (if (= (cdr (assoc 0 el)) "TEXT")
      (setq lst (append lst (list (list (cdr (assoc 1 el))))))
  (setq fn (vl-filename-mktemp nil nil ".csv"))
  (if (and lst (LM:WriteCSV (reverse lst) fn))
    (startapp "explorer" fn)
Júnior Nogueira.
Por favor,  Aceitar como Solução se meu post te ajudar.
Please Accept as Solution if my post helps you.
Message 4 of 27
adaptacad
@cadffm
These functions work very well, but are many decimal places, I would like to leave two.
besides understanding how the VLX works.
I would be very grateful if you could help me.
Message 5 of 27
devitg
Please upload your´s dwg , as dwg , not IMG or else
Message 6 of 27
cadffm
If the function works very well, you can change the excel cell format as simple way which you can go yourself.
How it works?
What question you have in detail?
Read Text content or pickpoints,
write them in the first empty row.
In detail there are many functions and many ways to do it.
If you have a concrete Lisp code question, ask them in Visual LISP, AutoLISP and General Customization Forum.
Sebastian
Message 7 of 27
vladimir_michl
Message 8 of 27
adaptacad
Thank you guys already get it!!!
but @vladimir_michl  how did you do that incredible lisp? or state secret?
Message 9 of 27
vladimir_michl
The source code of these apps is not public (unlike some of our other tools) but you can code a similar tool - Visual Lisp allows to control other objects, including Excel App objects, with all their properties and methods. See any ActiveX reference.
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
Message 10 of 27
j.belmonte
Dear all,
hi , version 1.9 has a problem when i select "rows" it doesn't begin in the appropriate cell in excel.
I use Autocad 2022.
Do you have any idea ?
Message 11 of 27
vladimir_michl
Thanks for your input, we will look at it.
Vladimir Michl, www.arkance-systems.cz - www.cadforum.cz
Message 12 of 27
j.belmonte
Thank you for your quick reply. Keep me in touch please (also i run Office 365 juste in case if this bug is related to the office suite)
Message 13 of 27
vladimir_michl
I am testing it in AutoCAD 2022, Excel 365, Click2XLS V1.9. When I select a row (by clicking on the row number in Excel), start the Click2XLS or Text2XLS command in AutoCAD and perform a mouse click, the respective data is written into the column "A" of that specific (selected) row. Do you use the same workflow?
Message 14 of 27
j.belmonte
It's always the same behaviour.
If i stay in columns, the lisp works great.
But in rows , if i start from cell A5, the texts start to be paste on cell B4.
If i start on AA5, it pastes on AB4 really weird.
Worse , if i start on A1, the program want to paste on B0 (line zero does not exists in excel) , or probably related to language, i have Office in French.
See extract when it wants to put the data in cell B0 witch no exists in excel :
Pick next text (column-mode) [insert Blank/Rows/eXit]: L-0507->[B0]
Error: Erreur Automation. Aucune description n'a été entrée.
Message 15 of 27
vladimir_michl
What confuses me is the "switch to Row mode" as Row mode is the default. So you switch to Column mode and then back to Row mode? And then it fails? I will check this.
UPDATE: I think you call the Column mode "rows", starts to make sense for me. Switching to Column mode just jumps 3 cells to the right -- if it is not the first point (as now added in V1.10).
PS: the thread probably gets too "individual", please e-mail me directly - vladimir.michl [at] arkance-systems.com
Message 16 of 27
j.belmonte
By default the texts are pasted vertically (column mode), but i need to have them pasted in row (horizontally, so i choose at each start to switch.
Message 17 of 27
murugan.231123
When i apload the click2xls lisp it not working and reply that excel application is not installed.
Can anyone resolve my issue.
the same application is working other computer.
the excel is already installed.
Message 18 of 27
vladimir_michl
First try the current version of Click2XLS from https://www.cadforum.cz/download - you have a very old one. If it still won't find your Excel, let's perform some diagnostics.
Message 19 of 27
murugan.231123
Thank you for the reply.
I find the lisp from the website ...the new version...thank you so much.
But the issue is not solved.
Can you help the diagnostics part where i can get this in below.
Message 20 of 27
vladimir_michl
You can find it in the freeware section or using a search:
https://www.cadforum.cz/en/download.asp?file=XLS
