Choose objects in current layer with ssget.
davidlanesmith673
davidlanesmith673
I am having some trouble with the ssget function. I want to just select objects within the curent active layer, but it isn't working. If I input the name manually then the code works.
(setq ss (ssget "WP" box '((-4 . "<AND") (-4 . "<OR") (0 . "TEXT") (0 . "LWPOLYLINE") (-4 . "OR>") (8 . "Road Points") (-4 . "AND>"))))
But when I replace the layer name by a variable, it says error: bad SSGET list value
(setq curLay (getvar "clayer"))
(setq ss (ssget "WP" box '((-4 . "<AND") (-4 . "<OR") (0 . "TEXT") (0 . "LWPOLYLINE") (-4 . "OR>") (8 . curLay) (-4 . "AND>"))))
Is there a way to get this to work, so I only select objects in the current layer?
pbejse
		box
		(list '(-4 . "<AND")
		      '(-4 . "<OR")
		      '(0 . "TEXT")
		      '(0 . "LWPOLYLINE")
		      '(-4 . "OR>")
		      (cons 8 curLay)
		      '(-4 . "AND>")
pbejse
Oops, wrong thread 🙂
I attached a lsp file here that was intended here
davidlanesmith673
Yah that works thanks! Could you explain why that works and mine doesn't? Why do you need list plus an apostrophe before each entry except for when cons is used?
pbejse
Good for you @davidlanesmith673 , glad it helps
The Apostrophe and the Quote Function saves me time to explain 🙂
davidlanesmith673
Thank you, that is very helpful!
