Check System Variable Value
C.Utzinger
Message 1 of 11
C.Utzinger
HI
I have a simple LSP for saving System Variables to registry and apply them.
There is a code part to test if the varible exists:
(if (and (/= spivar1 "")(not (getvar spivar1)))(alert (strcat "Systemvariable < " spivar1 " > existiert nicht!")))
but i want also test if the given value is good or not.
I tried something like:
(if (and (/= spiwer1 "")(not (setvar spivar1 (atoi spiwer1))))(alert (strcat "Systemvariablenwert < " spiwer1 " > nicht möglich!")))
but this don't work.
Any idea?
Replies (10)
Message 2 of 11
Kent1Cooper
I'm not familiar with those as System Variables -- they're not in Acad2017 here.  But if they are in the your-language version or an overlay program, and they're really System Variables and not variables you have created, then I see two things:
would always return nil, because I don't think System Variables ever do not exist -- don't they always have an initial or default value?
And this:
(/= spivar1 "")
should be this:
(/= (getvar spivar1) "")
and similarly elsewhere.
But if they're really variables you make yourself, then (setq) should be used instead of (setvar), and just the variable name instead of putting it in (getvar) functions.
Kent Cooper, AIA
Message 3 of 11
C.Utzinger
HI
Sorry I think there is a missunderstanding...
The hole code attached with the Dialog BOX would clear that.
But i just change that for better understanding...
(if (and (/= spiwer1 "")(not (setvar 'ORTHOMODE (atoi spiwer1))))(alert (strcat "Systemvariablenwert < " spiwer1 " > nicht möglich!")))
What i'm looking for is an alert message when the user introduce a wrong number for the Systemvariable.
For example <5> for the ORTHOMODE, this valuer does not exist, so (alert "this value does not exist for OTRHOMODE")
Message 4 of 11
ambrosl
You can use the VL-CATCH-ALL-APPLY, VL-CATCH-ALL-ERROR-P, and VL-CATCH-ALL-ERROR-MESSAGE functions to catch and test for an error.
Here is an example that might help, if the value passed to the ORTHOMODE system variable isn't valid the error returned by SETVAR is caught and the error message is displayed in an alert:
(setq testVal (vl-catch-all-apply 'setvar (list "orthomode" 5)))
(if (vl-catch-all-error-p testVal)
  (alert (vl-catch-all-error-message testVal))
Lee Ambrosius
Senior Principal Content Experience Designer
For additional help, check out the AutoCAD Developer Documentation
Message 5 of 11
C.Utzinger
That helps
Thank you very much!
Kind regards
Message 6 of 11
C.Utzinger
HI
I have still a little problem. Why does it work with numbers and not with words?
HPQUICKPREVIEW has a value ein/aus (on/off).
(vl-catch-all-apply 'setvar (list "HPQUICKPREVIEW" "ein"))
Or i'm doing something wrong :)...
Best regards
Message 7 of 11
C.Utzinger
Very strange!
With "EIN" it doesn't work, but with "AUS" it does.
Smiley Frustrated
Message 8 of 11
ambrosl
"EIN" didn't work for me, but I wonder if it is based on the language pack that is installed and being used though that shouldn't affect this situation.
Command: (setq testVal (vl-catch-all-apply 'setvar (list "HPQUICKPREVIEW" "ein")))
#<%catch-all-apply-error%>
Command: (vl-catch-all-error-message testVal)
"AutoCAD variable setting rejected: \"HPQUICKPREVIEW\" \"ein\""
Command: (setq testVal (vl-catch-all-apply 'setvar (list "HPQUICKPREVIEW" "aus")))
"AutoCAD variable setting rejected: \"HPQUICKPREVIEW\" \"aus\""
I would expect all strings to fail as the system variable is of the SWITCH type.  While HPQUICKPREVIEW at the Command prompt will accept ON, via the SETVAR function that same value is rejected and requires the use of 0 or 1.
Command: HPQUICKPREVIEW
Enter new value for HPQUICKPREVIEW <ON>: on
Command: (setvar "hpquickpreview" "on")
; error: AutoCAD variable setting rejected: "hpquickpreview" "on"
Enter new value for HPQUICKPREVIEW <ON>: 1
Command: (setvar "HPQUICKPREVIEW" 1)
1
Lee Ambrosius
Message 9 of 11
C.Utzinger
I just fixed it with this code:
(setq spiwer1 (cond ((= spiwer1 "EIN") "1")((= spiwer1 "AUS") "0")(T spiwer1)))
Now it works ;)...
Thank you and best regards
Message 10 of 11
ambrosl
Now it works ;)...
If you can ensure spiwer1 will always be EIN and AUS, then you shouldn't have any problems.  If the values might be lowercase or mixed-case, you might want to use the STRCASE to ensure the value is always uppercase only.
(= (strcase spiwer1) "EIN")
Lee Ambrosius
Message 11 of 11
C.Utzinger
Already done ;)...
Thank you
