Check "measurement" var. on dwg open
Message 1 of 8
Having discovered that drawings recovered after a crash ALWAYS have
MEASUREMENT set to "0",
I have been trying to get a little bit of lisp to check the status of
MEASUREMENT and, if it is not "1", prompt the user if he/she wants to change
it.
I have tried putting the routine in acaddoc.lsp, as partof S::STARTUP, and
in acad.lsp. I have been able to get the routine to run, but it does not
wait for the user to respond to the prompt.
Can anyone elighten me?
thanks
Keith P.
Balston & Company
Replies (7)
Message 2 of 8
Good intentions but it might be annoying to be prompted to change
MEASUREMENT for every valid setting of 0.
"Keith Pocock" wrote in message
news:[email protected]...
change
> it.
> thanks
> Keith P.
> Balston & Company
Message 3 of 8
Frank
He may be trying to set the undocmented measureinit variable since he's in
the UK.
"Frank Oquendo" wrote in message
> change
> > it.
and
> > thanks
> > Keith P.
> > Balston & Company
Message 4 of 8
As I see it, Frank, and I may be nearsighted:-). There are only two valid
settings for Measurement. Measurement = 1 means the drawing is a metric
(mm) drawing. Measurement = 0 means it is note.
For those who haven't run into this. When measurement = 1, Acad uses the
metric versions of acad.pat and acad.lin.
Michael Weaver
By day: Charles Bettisworth & Co.
[email protected]
By night: AlasCAD
[email protected]
AOL Instant messenger screen name:
AlasCAD
AUGI #w2170
> change
> > it.
and
> > thanks
> > Keith P.
> > Balston & Company
Message 5 of 8
Keith,
You might want to consider doing the following.
Within the s::startup add the following:
(if (findfile "autoload.lsp")(load (findfile "autoload.lsp")))
Then in the drawing directory for metric drawings create an autoload.lsp
file. Set all of your project specific settings in this file. I often use
this as a pseudo script by placing commands that update things like the
title block drawn date. I never have to worry about having the wrong date
on my drawings after doing this.
Michael Weaver
[email protected]
By night: AlasCAD
[email protected]
AlasCAD
AUGI #w2170
change
> it.
> thanks
> Keith P.
> Balston & Company
Message 6 of 8
Frank and Mike - thanks for the replies
Yes I am in the UK and ALL our drawings are metric (you know we dumped that
querky Imperial stuff years ago )
Hence it is very annoying to find that drawings recovered after a crash have
been reset to Imperial. It often goes unnoticed until a user cannot figure
out why hatches/linetypes are behaving strangely.
I have gone to the extreme of removing ACAD.PAT and ACAD.LIN from the search
paths (leaving the ISO versions in place), then the user gets notified that
MEASUREMENT is incorrect by a file not found error when hatching or
importing linetypes.
So yes, I _really_ do want to be notified if a drawing I have opened is
Imperial.
And what's the best way to achieve it please!!
thanks
Keith
> change
> > it.
and
> > thanks
> > Keith P.
> > Balston & Company
Message 7 of 8
Well, for notification you could include this at the end of your acad.lsp
or acaddoc.lsp S::Startup
(if (= 0 (getvar "measurement")) (alert "This drawing is Imperial"))
If you want to automatically change it to Metric, you could use:
(if (= 0 (getvar "measurement")) (setvar "measurement" 1))
Or to go further, you could do both by using:
(if (= 0 (getvar "measurement")) (progn
(alert "This drawing is Imperial . . . .\nAnd will be changed to Metric.
FD
Keith Pocock wrote in article
<[email protected]>...
that
have
figure
search
that
> Imperial.
> thanks
> Keith
> > change
> > > it.
S::STARTUP,
> and
not
> > > thanks
> > > Keith P.
> > > Balston & Company
Message 8 of 8
Thank you.
Will I be able to even further and offer the user the option with a Y/N
question, I wonder.
I'll try it and see......
Keith P.
"Flitter Dee" wrote in message
news:01bf5e01$a995ac80$d557d2d0@lms-1...
> FD
> that
> have
> figure
> search
> that
> > Imperial.
> > thanks
> > Keith
of
to
> > > change
> > > > it.
> S::STARTUP,
> > and
> not
> > > > thanks
> > > > Keith P.
> > > > Balston & Company
