Check number range for Overlap
cherrygate
Message 1 of 30
cherrygate
Hi!
I have a block attribute that has a number range in it (example: 12-24) and another attribute with an identifier(example: A1). I need a script that will get that block attribute from all of a certain block and then make sure there are no overlapping numbers and if there are tell me a list of which identifiers have overlap.
For example if I have:
Identifier: A1 Range: 12-24
Identifier: B1 Range: 24-48
Identifier: C1 Range: 49-62
Identifier: D1 Range: 1-13
Identifier: E1 Range: 20-30
The script would ideally output something like: “B1 + C1”, “D1 + A1”, “E1 + A1 + B1
Either a popup window or right in the command line area is fine. If no overlap found just output something like "All OK"
Here is a CAD file with this same example: https://drive.google.com/file/d/1L2fKoJDU96L03fvKjVPCqxl693ldDdPT/view?usp=sharing
Any help would be greatly appreciated, there are typically 100s of these per job and I have been checking them manually which takes me way too long. Thank you!
Accepted solutions (3)
Replies (29)
Message 21 of 30
pbejse
@cherrygate wrote:
So I have come across one issue while using it in the real world - Sometimes there isn't a number RANGE and just a single number in that attribute, and it doesn't work.
How would you specifically want the program to respond when there is only a single number?
Message 22 of 30
cherrygate
@pbejse wrote:
How would you specifially want the program to respond when there is only a single number?
Just count it as a single number "range." So for example - If A1 is 1-6 and B1 is 3 it would trigger the overlap call out
Message 23 of 30
pbejse
@cherrygate wrote:
Just count it as a single number "range." So for example - If A1 is 1-6 and B1 is 3 it would trigger the overlap call out..
Before we do any modification, what of that "FIBERS_USED" is not even a number? what if its blank? or a combination of numbers and letters?
It could happen
Message 24 of 30
cherrygate
It could happen
I am not sure what you mean by not an even number? Do you mean if it has a decimal place like 3.453? Decimals will never happen they will always be whole numbers.
If it is blank, I would say call it out in the overlap output list just so I know it needs to be looked at. If it is a combination of letters and numbers, again I would add it to the overlap output list so I know there is an error that needs to be fixed. The only other thing I can think of that might add "garbage" data into the mix is there being extra spaces in the number range (Maybe someone writes it like " 2 - 4 " instead of "2-4") if this happens I would prefer the extra spaces just get ignored/truncated and it reads it like a normal number range.
Maybe if there is a way to handle those exceptions so that any data in that attribute that doesn't fit into the parameters it is looking for it calls that out in a separate list maybe? So it could output overlap list and then error list? Just an idea.
Thanks again for everything, I seriously appreciate your help.
Message 25 of 30
pbejse
@cherrygate wrote:
..Maybe if there is a way to handle those exceptions so that any data in that attribute that doesn't fit into the parameters it is looking for it calls that out in a separate list maybe? So it could output overlap list and then error list? Just an idea.
(defun c:clash ( / _SpacedOut _range low high ovl attbv blocks i lst a b f invalid WTPD)
;;		 pBe June 2021			;;;
(defun _SpacedOut (str)
  (vl-list->string (vl-remove 32 (vl-string->list str))))
(defun _range (n m l / ol )
	(while
	  (and n m (or (< (low n) (low m) (high n))
		       (eq (cadr n)(cadr  m))))
		(setq ol (strcat (car n)"+"(car m)))
		(setq n (list ol (strcat (itoa (low n))"-"
					 (itoa (max (high m)(high n)))))
		        l (cdr l) m (car l) )
   (list ol l)
  (setq low (lambda (s)(atoi (cadr s))))
  (setq high (lambda (s)
	   (atoi
	     (substr (cadr s) (+ 2 (vl-string-position 45 (cadr s))))
  (if (setq WTPD (ssadd) blocks (ssget '((0 . "INSERT")(66 . 1))))
    (progn
	    (repeat (setq i (sslength blocks))
		(setq attbv (mapcar '(lambda (At)
				       (list (Vla-get-tagstring at)
					     (_SpacedOut (Vla-get-textstring at))))
				       (Vlax-invoke (vlax-ename->vla-object
						      (ssname blocks (setq i (1- i)))) 'GetAttributes)))
	          (cond
		    ((null (Setq f (mapcar '(lambda (tg)(cadr (assoc tg attbv)))
						 '("TERM_TAG" "FIBERS_USED"))))
		    ( (wcmatch (setq r (Cadr f)) "*#-#*")(setq lst (Cons f lst)))
		    ( (numberp (read r))
			  (setq lst (Cons (list (Car f) (strcat r "-" r)) lst))
		    ( (setq invalid (cons (Car f) invalid))
			     (ssadd (ssname blocks i) WTPD)
           	(setq lst (Vl-sort lst '(lambda (a b)  (< (atoi (cadr a))(atoi (cadr b))))))
		(While  (setq a (car lst))
		      (setq b (Cadr lst))
			(if (Car (setq f (_range a b (cdr lst)))) (setq ovl (cons (Car f) ovl)))
			(setq lst (cadr f))
    (princ "\nNo valid blocks found")
  (if (or ovl invalid)
   (foreach itm (list
		 (list "\nOverlap: " ovl)
		 (list "\nWeird things people do: " invalid))
      (if (cadr itm)
	(princ (strcat (Car itm)
	  (substr (apply 'strcat (mapcar '(lambda (v)(strcat " | " v )) (reverse (cadr itm)))) 4)))
	(Alert "All OK")
  (sssetfirst  nil WTPD)
  (princ)
Command: Clash
Select objects: Specify opposite corner: 11 found
Select objects:
Overlap: A1+K1+H1+D1+B1 | F1+C1 | E1+G1
Weird things people do: Q2 | Q1
K1 : single number
C1 : Space after dash
E1 : Space before dash
Q1 : "I have a apple"
Q2 :                                         <---- ( what are you looking for? its blank)
HTH
Side note: overlap |  overlapped  | overlapping?
Message 26 of 30
cherrygate
This is perfect. Thank you so much for all the help! It's very much appreciated.
Message 27 of 30
ronjonp
I was on vacation so no time to play earlier in the week. Here's a quick mod to my existing code to possibly catch the other exceptions and highlight errors:
(defun c:foo (/ a b mn mx r r2 s s2)
  ;; RJP » 2021-06-18
  (cond
    ((setq s (ssget '((0 . "INSERT") (66 . 1))))
     (foreach e	(vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
       (if
	 (and (= 'str (type (setq a (vl-catch-all-apply 'getpropertyvalue (list e "TERM_TAG")))))
	      (= 'str (type (setq b (vl-catch-all-apply 'getpropertyvalue (list e "FIBERS_USED")))))
	  (setq r (cons (list a (read (vl-string-translate "-" " " (strcat "(" b ")"))) e) r))
     (setq s2 (ssadd))
     ;; Check if attribute is empty or does not contain all numbers
     ;; Read already stripped out extraneous spaces (read " (  1  -  2  ) ")
     (setq r (vl-remove-if
	       '(lambda	(x)
		  (and (or (null (cadr x)) (null (vl-every 'numberp (cadr x))))
		       (ssadd (last x) s2)
		       (princ (strcat "\nBAD JUJU WITH: " (car x)))
	       r
     (setq r (vl-sort r '(lambda (r j) (< (caadr r) (caadr j)))))
     (while (setq a (car r))
       (setq mn (caadr a))
       (setq mx (cadadr a))
       (setq r2 (vl-remove-if-not '(lambda (x) (or (<= mn (caadr x) mx) (<= mn (cadadr x) mx))) r))
       (foreach e r2 (setq r (vl-remove e r)))
       (if (= (length r2) 1)
	 (princ (strcat "\n" (car a) " - OK :)"))
	 (print (vl-sort (mapcar 'car r2)'<))
     (sssetfirst nil s2)
  (princ)
Returns:
BAD JUJU WITH: W1
BAD JUJU WITH: Y1
("A1" "D1" "Z1")
("B1" "E1")
C1 - OK 🙂
Message 28 of 30
cherrygate
	(while
   (list ol l)
	   (atoi
    (progn
	          (cond
		      (setq b (Cadr lst))
			(setq lst (cadr f))
   (foreach itm (list
      (if (cadr itm)
	(Alert "All OK")
  (princ)
Command: Clash
Select objects:
K1 : single number
HTH
After using this for a few months I have found a situation it doesn't handle correctly (And the other variations of this script seem to miss too)
Example:
A1: 780
B1: 775-780
It seems that it doesn't check the last number in the group and looks like it is just checking 775-779 instead.
Any assistance modifying this script to handle that would be highly appreciated. Thank you!
Message 29 of 30
pbejse
Example: A1: 780 B1: 775-780
That's really embarassing 😁,  I do apologies for that.
Not sure but a quick look at the code tells me this could be it:
	(while
	  (and n m (or (<= (low n) (low m) (high n))
   (list ol l)
HTH
Message 30 of 30
cherrygate
Thanks again for all your help, that fixed it!!
