Changing the polyline closed polygon in place where single line intersected him
miroslav.pristov
Message 1 of 26
miroslav.pristov
Is any one interesting to please help me making this lisp
I have polyline closed polygon (in yellow), like on picture bellow and in the example file i attach. The shape of it can be different, this is only the example. I have a line on drawing which intersect the polygon (white line). i need that polygon to change its shape in intersection points A and B like on pictures. To trim the polygon and to add new line A to B in it. The white line must not be erased. Also if i choose some line for defining the UCS (red line) i need that line AB to be dimaligned like on picture and example file.
So the input data should be:
-pick polygon,
-pick white line,
-pick side from white line for triming the polygon,
-pick red line for defining UCS
Thanks for help
Replies (25)
Message 21 of 26
ВeekeeCZ
@miroslav.pristov wrote:
But there is one thing and that really bothers me. I realize that my idea of drawing dimension lines in ucs which i got choosing magenta line is not a good solution. Because i dont know how will program choose UCS and thats why there are cases, where i got the dimension lines upside down.
I think the UCS could be manageable. Maybe little more complicated, but yes. But I guess it does not worth it. It could work more simple and probably better.
Btw Now remember, when you are selecting the object to trim (the main one) select that close to the corner (that one, where the future dims will cross each other).
Spoiler
(defun c:TrimPolygon ( / LM:intersections *error* adoc ensel emsel esel pt)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (vla-endundomark adoc)
    (princ))
  ;; Intersections  -  Lee Mac
  ;; Returns a list of all points of intersection between two objects
  ;; for the given intersection mode.
  ;; ob1,ob2 - [vla] VLA-Objects
  ;;     mod - [int] acextendoption enum of intersectwith method
  (defun LM:intersections ( ob1 ob2 mod / lst rtn )
    (setq lst (vlax-invoke ob1 'intersectwith ob2 mod))
    (repeat (/ (length lst) 3)
      (setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn)
	    lst (cdddr lst)))
    (reverse rtn))
  (if (and (setq ensel (entsel "\nSelect cutting edge: "))
	   (setq emsel (entsel "\nSelect outer object to trim close to corner: "))
	   (setq pt (osnap (cadr emsel) "_end"))
    (progn
      (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
      (if (= 2 (length (setq pts (LM:intersections (vlax-ename->vla-object (car ensel))  (vlax-ename->vla-object (car emsel)) acextendnone))))
	(setq a (car pts)
	      b (last pts)))
      (command "_.PEDIT" emsel "_Cl" ""
	       "_.TRIM" ensel "" emsel)
      (while (> (getvar 'CMDACTIVE) 0)
	(command PAUSE))
      (command "_.PEDIT" emsel "_Cl" "")
      (command "_dimlinear" "_none" a "_none" b "_R" "_none" pt "_none" b "_none" (polar a (angle a pt) (+ (distance a pt) 0.5))
	       "_dimlinear" "_none" a "_none" b "_R" "_none" pt "_none" a "_none" (polar b (angle b pt) (+ (distance b pt) 0.5)))
  (*error* "end")
.... I realize that I am engaged you with these last few days, and i am really grateful on that.
Thank you again
If so, let it show by the means the page offers you. Just close the thread as solved and give some kudo. Not just to me, to all people who helped you somehow. Even the suggestion you did not take, even that guy tried to help you.
Message 22 of 26
miroslav.pristov
Thank you again for your time and effort.
The problem with text direction of dimension lines now are ok, but there is other problem which i didnt have it before.
As you can see the dimension lines are not in ucs of magenta line. One must be parallel and the other must be orthogonal to that line. So i think calling for that line is necessary. In first example i think its ok, or maybe the angle is pretty much similar so i cant see the difference (thats not the one on picture), but in this one like in picture its clearly visible.
And one more thing. I see that you make automaticaly position of dimension lines. Its ok but on my drawings i have many other lines and dimension lines, so i deliberately left that in previous lisp i send. I must put them somewhere on clean space.
Dont worry the kudo is ready 🙂
Message 23 of 26
ВeekeeCZ
Ok, I can see the issue. The difference is whether you cut just one corner, or two corners. But the fix is very simple. It's all the same, just little of thinking.
Spoiler
    (princ))
	    lst (cdddr lst)))
    (reverse rtn))
	   (setq p1 (osnap (cadr emsel) "_end")
		 p2 (osnap (cadr emsel) "_mid"))
    (progn
	(setq a (car pts)
	      b (last pts)))
	(command PAUSE))
      (command "_dimlinear" "_none" a "_none" b "_R" "_none" p1 "_none" p2 PAUSE
	       "_dimlinear" "_none" a "_none" b "_R" "_none" p2 "_none" p1 PAUSE)
  (*error* "end")
Never mind. Save it, please.
Message 24 of 26
miroslav.pristov
now the first one example work as the second yesterday 😞
Message 25 of 26
miroslav.pristov
actually it works. i saw now you put to choose close to corner. When i do that it works
Thank you very much
Message 26 of 26
ВeekeeCZ
It certainly does NOT to me. Post the dwg sample where is this happening. Please test more then one sample. If it goes wrong, focus on some envirnment variables you could have on (ORTHO, SNAP...).
Edit: Glad, you sorted out.
