Changing TextStyle on Specific Mleaderstyles via (V)LISP via a List
Hi all,
I have pieced together a function (with several sub-functions I've found here - props to all other authors I borrowed from) to:
  1. Evaluate if a specific mleaderstyle exists in the drawing
  2. If it's present, change the Textstyle to Standard
Code:
(DEFUN RESETMLEADERS ()
  ;;function to test if mleaderstyle exists
  (defun mLeaderstyleExist (styl / dict result)
    (if	(setq dict (dictsearch (namedobjdict) "ACAD_MLEADERSTYLE"))
      (foreach x dict
	(if (and (= (car x) 3)
		 (eq (strcase (cdr x)) (strcase styl))
	  (setq result t)
    result
  ;;reset mleaderstyle "HEX-ARROW"
  (defun RESEThexa ()
	  dict1	(member (cons 3 "HEX-ARROW") dict)
	  el1	(entget (cdr (assoc 350 dict1)))
	  er	(tblobjname "style" "Standard")
    (entmod (subst (cons 342 er) (assoc 342 el1) el1))
  ;;reset mleaderstyle "HEX-DOT"
  (defun RESEThexd ()
	  dict1	(member (cons 3 "HEX-DOT") dict)
  ;;reset mleaderstyle "HEX-LOOP"
  (defun RESEThexl ()
	  dict1	(member (cons 3 "HEX-LOOP") dict)
  ;;reset mleaderstyle "HEX-TILDE"
  (defun RESEThext ()
	  dict1	(member (cons 3 "HEX-TILDE") dict)
  ;;check if mleaderstyle exists - if so, run its RESET function
  (IF
    (mleaderstyleexist "HEX-ARROW")
     (RESEThexa)
     (PRINC)
  )					;END IF
;;;__________________________________
  (IF
    (mleaderstyleexist "HEX-DOT")
     (RESEThexd)
     (PRINC)
  )					;END IF
  (IF
    (mleaderstyleexist "HEX-LOOP")
     (RESEThexl)
     (PRINC)
  )					;END IF
  (IF
    (mleaderstyleexist "HEX-TILDE")
     (RESEThext)
     (PRINC)
  )					;END IF
)					;end defun RESETMLEADERS
While this RESETMLEADERS function works, I think it could be done more efficiently by:
  1. passing a list of mleaderstyles to look for (instead of defining a ton of individual subfunctions)
  2. and for each that exists in the drawing
  3. set the textstyle to Standard.
The thing is, I'm not really strong with the syntax to pass/evaluate lists and doing something foreach.
If someone could point me in the direction of just the general structure of how to do this with mleaderstyles, I'd really appreciate it.
I understand that VLISP can be more efficient when working with mleaderstyles - but I'm even less proficient with VLISP.
Thanks so much!
SeeMSixty7
You are correct. Just glancing through you could do something like this.
      (foreach x dict
	  (setq result t)
    result
;;;;;;;;;;;;Added the list of mleaders styles (setq mleaderlist (list "HEX-ARROW" "HEX-DOT" "HEX-LOOP" "HEX-TILDE"))
;;;;;;;;;;;; created your local function to update a mleaderstyle (defun ResetTheMLeader (mleaderstylename) (setq dict (dictsearch (namedobjdict) "ACAD_MLEADERSTYLE") dict1 (member (cons 3 mleaderstylename) dict) el1 (entget (cdr (assoc 350 dict1))) er (tblobjname "style" "Standard") ) (entmod (subst (cons 342 er) (assoc 342 el1) el1)) ) ;;;step through the list and update (foreach mleaderitm meladerlist (resetthemleader mleaderitm) ) ) ;end defun RESETMLEADERS
Good luck
Thanks for tidying up my code, SeeMSixty7 - it works!
Just so I can apply this moving forward - am I correct in seeing that you:
  1. set a variable named MLEADERLIST comprising the list of mleaderstyles to evaluate for in the drawing
  2. then, with the "foreach", it assigns each list element of the MLEADERLIST variable to a floating variable called MLEADERITM
  3. for each found list element at MLEADERITM, execute the RESETTHEMLEADER function
Is that a basic structure of how identifying a LIST and <do something> FOREACH works? If so, I think I finally get it! 🙂
For posterity, here's my final cleaned-up version:
  (foreach mleaderitm mleaderlist
Thanks again!
SeeMSixty7
That is correct. Code looks good. Sounds like you have it down.
Good luck!
ronjonp
FWIW, you could add a couple of checks to make sure that the mleader dictionary and standard style exist as well as feed it a list of names directly. Also be sure to localize your variables ( bold below ). 8-)
(defun resetthemleaders	(mleaderstylenames / dict el1 er)
  (if (and (setq dict (dictsearch (namedobjdict) "ACAD_MLEADERSTYLE"))
	   (setq er (tblobjname "style" "Standard"))
    (foreach mln mleaderstylenames
      (if (setq el1 (dictsearch (cdr (assoc -1 dict)) mln))
;; (resetthemleaders '("HEX-ARROW" "HEX-DOT" "HEX-LOOP" "HEX-TILDE"))
Thanks, RONJONP!
This has worked, too... I think I understand how this works, now that I've gotten my head around FOREACH.
Thanks!
ronjonp
Glad you're learning 🙂 One advantage of passing a list to the function is this:
Can be set outside of the loop which should help with performance ( not that we'd notice ) 8-).
