Open AutoCAD: Launch the AutoCAD program on your computer.
Access the Options menu: Click on the "gear" icon or type "OPTIONS" in the command line to open the Options dialog box.
Navigate to the "Files" tab: In the Options dialog box, switch to the "Files" tab.
Select "Support File Search Path": Under the Support File Search Path section, click on the "plus" icon (+) to expand the list.
Click on "Language": Locate and click on the "Language" entry in the list.
Edit the language settings: In the right-hand pane, you'll see the directories where AutoCAD looks for language files. By default, the first location is the installation folder. You can modify this list by adding or rearranging paths.
Add the Finnish language files: Make sure you have the Finnish language files for AutoCAD. If you have them, click on the "Add..." button and navigate to the directory where the Finnish language files are located. Select the appropriate folder and click "OK" to add it to the list.
Set Finnish as the default language: In the "Language" section, select the Finnish language from the drop-down menu as the preferred language.
Apply and close: Click "Apply" and then "OK" to save the changes and close the Options dialog box.
Restart AutoCAD: Close and reopen AutoCAD for the language changes to take effect.
Please note that the steps provided are based on the general process for changing the language settings in AutoCAD. The exact steps or menu names may vary depending on the version of AutoCAD you are using.
https://wawruk.pl/oferta/ogrodzenia/
