Visual LISP, AutoLISP and General Customization
change vlx command
6 REPLIES 6
nychoe1
1487 Views, 6 Replies
change vlx command
hi.
I wish everybody a Happy New Year!
I have two vlx file.
blocktotable.vlx       --> command : bt
blocktotextli.vlx       --> command : bt
two vlx files have same command.
but I want to
blocktotextli.vlx       --> command : bxt     <--- like this
of course, I know that cannot modify vlx files
how to use command : bxt
Give me some feedback.
6 REPLIES 6
regisrohde
in reply to: nychoe1
It is not possible to edit VLX, and the same commands, conflict, making the command last loaded VLX is called.
To change is necessary to have the original file .LSP
Please mark this as the solution if it resolves your issue.Kudos gladly accepted.
Regis Rohde
rkmcswain
Edit the original source code.
ВeekeeCZ
@nychoe1 wrote:
hi.
but I want to
If you cannot change the code or contact one of the authors... then you can load it each time you run it to make sure it's the last one. (but you need to change the both names.)
(defun c:bta nil
  (load "blocktotable.vlx")
  (c:bt)
  (princ)
(defun c:bxt nil
  (load "blocktotextli.vlx")
  (c:bt)
  (princ)
regisrohde
in reply to: regisrohde
if not have the source code can use the following "alternative solution".
Save the VLX 2 on c :, and then change the path in the code below:
(defun c:bxt()
(load c:\\blocktotextli.vlx)
(c:bt)
(load c:\\blocktotable.vlx)
(princ)
Regis Rohde
dgorsman
... and thats exactly why you should always use verbose command names.  Let the user set up the PGP file, or a LISP wrapper function, or whatever if they want to use BT, or BTX, etc.
stevor
Old threat but:
1. For
" blocktotable.vlx       --> command : bt
blocktotextli.vlx       --> command : bxt     <--- like this...
how to use command : bxt"
You might make a routine of some name, like C:BXTT,
that would load only 'blocktotextli.vlx' and then
execute its 'C:BT' command.
Same for blocktotable.
2. And I repeat, beware of the contents of
things you cannot see, as in VLX and FAS.
S
AutoCAD Inside the Factory
