Change vis state with dialog box
charles_neelyFG4LK
Message 1 of 18
charles_neelyFG4LK
I have a lisp that will change the visibility state of a dynamic block in all layouts (h/t Lee Mac). I would like to use a dialog box with either a list or a pull-down menu to set the variable for the visibility state. Can anyone help with that?
Replies (17)
Message 2 of 18
paullimapa
Could you share that lisp and the dynamic block that you want this to work on?
Paul Li
IT Specialist
@The Office
Message 3 of 18
charles_neelyFG4LK
Here are the files
Message 4 of 18
paullimapa
so when you click on the down triangle, you don't like to select the visibility states options from that list?
Paul Li
IT Specialist
@The Office
Message 5 of 18
charles_neelyFG4LK
The lisp will change the vis state in all layouts which is desirable. Typically there are multiple layouts.
Message 6 of 18
paullimapa
try VSetP.lsp...no dialog box but select a # list from cursor menu.
Load & run VSetP then select the dynamic block in this case WSB-SCALE-DYN on the drawing screen and you'll get this # list to select from:
Paul Li
IT Specialist
@The Office
Message 7 of 18
ВeekeeCZ
Found a routine that I've posted already before.... to match the visibility state. Just fix one, then run the routine to match the rest.
(vl-load-com)
(defun c:MatchVisibility ( / LM:getvisibilityparametername e p v s i)
  ;; http://www.lee-mac.com/dynamicblockfunctions.html#getvisibilityparametername
  (defun LM:getvisibilityparametername ( blk / vis )
    (if (and (vlax-property-available-p blk 'effectivename)
	     (setq blk (vla-item (vla-get-blocks (vla-get-document blk))
				 (vla-get-effectivename blk)))
	     (= :vlax-true (vla-get-isdynamicblock blk))
	     (= :vlax-true (vla-get-hasextensiondictionary blk))
	     (setq vis (vl-some '(lambda ( pair ) (if (and (= 360 (car pair))
							   (= "BLOCKVISIBILITYPARAMETER" (cdr (assoc 0 (entget (cdr pair))))))
						    (cdr pair)))
				(dictsearch (vlax-vla-object->ename (vla-getextensiondictionary blk)) "ACAD_ENHANCEDBLOCK"))))
      (cdr (assoc 301 (entget vis)))))
  (if (and (setq e (car (entsel "\nSelect source block: ")))
	   (or (= "INSERT" (cdr (assoc 0 (entget e))))
	       (prompt "\nError: Selected object is not a block!"))
	   (or (setq p (LM:getvisibilityparametername (vlax-ename->vla-object e)))
	       (prompt "\nError: Selected block has no visibility parameter!"))
	   (setq v (getpropertyvalue e (strcat "AcDbDynBlockProperty" p)))
	   (setq s (ssget "_A" '((0 . "INSERT"))))
    (repeat (setq i (sslength s))
      (if (setq p (LM:getvisibilityparametername (vlax-ename->vla-object (setq e (ssname s (setq i (1- i)))))))
	(vl-catch-all-apply 'setpropertyvalue (list e (strcat "AcDbDynBlockProperty" p) v)))))
  (princ)
Message 8 of 18
charles_neelyFG4LK
Got this error when running that lisp
; error: bad argument type: stringp nil
Message 9 of 18
paullimapa
Here's a new code VSetPW.lsp that lets you select from a window list box.
PS: Double clicking will also dismiss the list box with the current item selected
Paul Li
IT Specialist
@The Office
Message 10 of 18
ВeekeeCZ
Sorry, difficult to fix since I'm not able to replicate the issue.
Message 11 of 18
komondormrex
@charles_neelyFG4LK
check this mod to your code
;Contains lisp routines to change the visibility state of the WSB-SCALE-DYN block
;This is for the Renewables Group
;If there are any issues with its use please contact Charlie Neely, [email protected]
(defun c:ChgScaleBlock ()
    (setq blk "WSB-SCALE-DYN" ;; Block Name
;;          vis "1 = 10"    ;; New Visibility State
;;			komondormrex
		   _list '("1 = 10" "1 = 20" "1 = 30" "1 = 40" "1 = 50" "1 = 60" "1 = 100" "1 = 200" "1 = 300" "1 = 400"
				   "1 = 500" "1 = 600" "1 = 700" "1 = 800" "1 = 1000" "1 = 1500" "1 = 2000" "H 1 = 20 V 1 = 4" "H 1 = 20 V 1 = 5"
				   "H 1 = 20 V 1 = 10" "H 1 = 30 V 1 = 4" "H 1 = 30 V 1 = 5" "H 1 = 30 V 1 = 10" "H 1 = 40 V 1 = 4"
				   "H 1 = 40 V 1 = 5" "H 1 = 40 V 1 = 10" "H 1 = 50 V 1 = 4" "H 1 = 50 V 1 = 5" "H 1 = 50 V 1 = 10"
				   "H 1 = 100 V 1 = 5" "H 1 = 100 V 1 = 10" "H 1 = 20 V 1 = 4 BAR" "H 1 = 20 V 1 = 5 BAR" "H 1 = 20 V 1 = 10 BAR"
		   vis (get_listed_choice vis "Pick Visibility State" _list nil)
;;			komondormrex
    (if (and vis (setq sel (ssget "_X" (list '(0 . "INSERT") (cons 2 (strcat "`*U*," blk)) '(410 . "~Model")))))
        (repeat (setq idx (sslength sel))
            (if (= (strcase blk) (strcase (blockname (setq obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))))))
                (SetVisibilityState obj vis)
    (princ)
;; Block Name
;; Returns the true (effective) name of a supplied block reference
(defun blockname ( obj )
    (if (vlax-property-available-p obj 'effectivename)
        (defun blockname ( obj ) (vla-get-effectivename obj))
        (defun blockname ( obj ) (vla-get-name obj))
    (blockname obj)
;; Set Dynamic Block Visibility State
;; Sets the Visibility Parameter of a Dynamic Block (if present) to a specific value (if allowed)
;; blk - [vla] VLA Dynamic Block Reference object
;; val - [str] Visibility State Parameter value
;; Returns: [str] New value of Visibility Parameter, else nil
(defun SetVisibilityState ( blk val / vis )
    (if
        (and
            (setq vis (getvisibilityparametername blk))
            (member (strcase val) (mapcar 'strcase (getdynpropallowedvalues blk vis)))
        (setdynpropvalue blk vis val)
;; Set Dynamic Block Property Value  -  Lee Mac
;; Modifies the value of a Dynamic Block property (if present)
;; prp - [str] Dynamic Block property name (case-insensitive)
;; val - [any] New value for property
;; Returns: [any] New value if successful, else nil
(defun setdynpropvalue ( blk prp val )
    (setq prp (strcase prp))
    (vl-some
       '(lambda ( x )
            (if (= prp (strcase (vla-get-propertyname x)))
                (progn
                    (vla-put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))
                    (cond (val) (t))
        (vlax-invoke blk 'getdynamicblockproperties)
;; Get Dynamic Block Property Allowed Values
;; Returns the allowed values for a specific Dynamic Block property.
;; Returns: [lst] List of allowed values for property, else nil if no restrictions
(defun getdynpropallowedvalues ( blk prp )
    (vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'allowedvalues)))
;; Get Visibility Parameter Name
;; Returns the name of the Visibility Parameter of a Dynamic Block (if present)
;; Returns: [str] Name of Visibility Parameter, else nil
(defun getvisibilityparametername ( blk / vis )
    (if
        (and
            (setq blk
                (vla-item
            (setq vis
                (vl-some
                   '(lambda ( pair )
                        (if
                            (and
                                (= 360 (car pair))
                            (cdr pair)
                    (dictsearch
;	komondormrex, apr 2025
(defun get_listed_choice (set_choice list_prompt _list multiple / dcl_lines dcl_filename_full glc_dcl_id _list
														 		  dialog_result selected_choices default_choice
	(defun write_dialog_file (dcl_lines / temp_file_path dcl_filename_full dcl_file_id)
		(setq temp_file_path (vla-get-TempFilePath (vla-get-Files (vla-get-preferences (vlax-get-acad-object))))
			  dcl_filename_full (vl-filename-mktemp "Dialog" temp_file_path ".dcl"])
			  dcl_file_id (open dcl_filename_full "w")
		(mapcar '(lambda (dcl_str) (write-line dcl_str dcl_file_id))
				 dcl_lines
		(close dcl_file_id)
		dcl_filename_full
	(defun populate_list ( list_key list_to_process )
		(start_list list_key 3)
			(mapcar 'add_list
				  	(mapcar '(lambda (list_element)
				  			 	(strcat "\n" list_element)
				  			 list_to_process
		(end_list)
	(setq dcl_lines (list "List_Box : dialog {"
												"initial_focus = \"List_Box\";"
									  			(strcat "label = \"" list_prompt "\";")
												": list_box {"
																"key = \"List_Box\";"
																"width = 50;"
																"height = 20;"
																"allow_accept = true;"
																(if multiple "multiple_select = true;" "")
														   "ok_cancel;"
		  dcl_filename_full (write_dialog_file dcl_lines)
		  glc_dcl_id (load_dialog dcl_filename_full)
	(if glc_dcl_id
		(if (new_dialog "List_Box" glc_dcl_id)
			(progn
				(populate_list "List_Box" _list)
				(if (setq default_choice (vl-position set_choice _list))
					(set_tile "List_Box" (itoa default_choice))
;					(set_tile "List_Box" "0")
				(action_tile "List_Box" "(cond
											((= 4 $reason) (setq selected_choices $value))
											(t (setq selected_choices $value))
				(setq dialog_result (start_dialog))
				(unload_dialog glc_dcl_id)
				(vl-file-delete dcl_filename_full)
				(cond
						((= dialog_result 1)
							(if selected_choices
								(if multiple
									(setq selected_choices (mapcar '(lambda (index) (nth index _list))
																	(read (strcat "(" selected_choices ")"))
									(setq selected_choices (nth (atoi selected_choices) _list))
						(t (setq selected_choices nil))
Message 12 of 18
Sea-Haven
@komondormrex if you have a block and can select it then this should produce _list.
(setq obj (vlax-ename->vla-object (car (entselect '\nPick a block "))))
(setq visval (LM:getvisibilityparametername obj))
(setq _lst (LM:getdynpropallowedvalues obj visval))
Message 13 of 18
paullimapa
which is exactly how I did that in my code I posted previously:
Paul Li
IT Specialist
@The Office
Message 14 of 18
Sea-Haven
Sorry @paullimapa missed that, because there is more than 20 visibility states yes have to use a list box, rather than say a radio button solution, which I cut the code from. Just me would have had 2 blocks one for 1:x and the other for V x & H y, bit easier to choose.
If the 1:x is used with a layout viewport to indicate scale you can get the viewport scale so would auto set to correct 1:x without need for selecting scale.
Message 15 of 18
paullimapa
tricky thing is the 2nd portion of the lists contains selections that would give you multiple scales or multiple scale bars:
Paul Li
IT Specialist
@The Office
Message 16 of 18
komondormrex
@Sea-Haven
and if you have only the block name, like in the op's code? i mean you start the code getting the block name to do dialog, nothing's been selected so far. and btw i'd prefer it lm free))) i mean there is nothing that complex to write such a code from scratch, for me to be correct)))
Message 17 of 18
ВeekeeCZ
Try the updated code. It should overcome the error.
Message 18 of 18
charles_neelyFG4LK
Been away from this for a few days. Thanks for the help with this, got me all set up!
