change the same tag value extension for batch attribute definition
manudug
manudug
I would like to know if someone knows how to modify the same extension in the tag value using a find-and-replace method for multiple attributes.
See the pictures for an explanation
Thanks for your help
Emmanuel Duguet, P.Eng
Automation specialist and AutoCAD Electrical Trainer
Please Accept as Solution if I helped you. Kudos are also much appreciated.
Replies (13)
pendean
Community Legend
Community Legend
Share that / those images as a DWG file here please.
manudug
Here is the file
Sea-Haven
Bit of a weird dwg, you have attribute definitions not a block with say single attribute. You could add text which shows the attdef actual value say on another layer, is that what you want  the "A15"
paullimapa
As @Sea-Haven replied, your drawing does not contain attributes but attribute defintions.
Do you want to find and replace the attribute definition tag names?
Is it designed to be inserted as a block into another drawing so that you can then fill out the attributes?
Paul Li
IT Specialist
@The Office
paullimapa
If you really want to replace Attribute Definition Tag Names then try this attached lisp file.
After loading adtagf&re.lsp and running adtagf&re you'll be asked to enter ending value to find and replace.
Paul Li
IT Specialist
@The Office
manudug
Thanks a lot, Paul.
It's exactly what I'm looking for.
It will accelerate my future block modification.
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
Luke_Poirier
Is there any way you can make a version of this that can do block definition renaming update across several attributed blocks that have the same attribute name? I'd like to batch change all my blocks in a file that have an attribute named "_size" to read "size"
paullimapa
What's the name of the Block?
Can you share a sample dwg with this Block?
Paul Li
IT Specialist
@The Office
Luke_Poirier
Sorry I'm not able to share the file. It's several hundred blocks all in one file's model space. That being said, it would be nice to extend the action into paper spaces too. This library of blocks share many of the same attribute definitions that I'd like to batch change rather than going into each block or doing BATTMAN over and over.
paullimapa
So it sounds like in this one dwg you have lots of blocks but with different names that have already been inserted in model as well as paper space and may contain attributes and some of these contain the same tag name called _size but you want them to be renamed to size?
Paul Li
IT Specialist
@The Office
Luke_Poirier
That is correct. I did a little more digging this morning and found something I was able to make work. It requires you to enter in the new and old attributes directly into the .lsp file and you can do a list of them if you have to do this for more than one attdef. It would be nice if the lisp could be generic and ask you inside autocad to enter the existing and new attribute names. The lisp name is RepEng and can be found here. https://www.cadtutor.net/forum/topic/23977-change-attribute-tags-for-blocks-using-lisp/
paullimapa
Try attached ABTagRepN.lsp which gives you the option to:
Enter Current Attribute Tag Name to Replace:
Enter New Attribute Tag Name:
ABTagRepN can also will then search through both model & layouts for Blocks with the matching Attribute Definition Tag Name and replace with New.
It'll also do the same with the Block definitions so any new Blocks with those Attributes when inserted will show the new Tag Name.
Paul Li
IT Specialist
@The Office
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
