change text height
change text height
Ranjit_Singh
Advisor Advisor
Message 1 of 17
change text height
Ranjit_Singh
I wrote this simple LISP to change text height to 0.1 everywhere in the drawing. VLIDE does not give me any error. But when I run it just sits there. Seems like there is an endless loop. What am I doing wrong.
Thanks.
(defun c:chtxt(/ ss i a b)
(setq ss (ssget "_x" '((0 . "*text*"))))
(setq a (ssname ss i))
(setq i 0)
(while (/= a NIL)
(setq b (entget a))
(setq b (subst '(40 0.1) (assoc 40 b) b))
(entmod b)
(1+ i)
(princ)
Replies (16)
Message 2 of 17
Satoews
(setq i 0)
(while (/= a NIL)
(setq b (entget a))
(entmod (subst (40 0.1) (assoc 40 b) b))
(1+ i)
(princ)
try this
edit: screwed up the lisp
Shawn T
Message 3 of 17
Ranjit_Singh
I see u combined the entmod and setq b statements, which is a good thing, but now I get this error
; error: bad argument type: numberp: nil
Not sure how to fix it. I think it has something to do with the loop, but not sure what exactly. Is this statement valid?
(while (/= a NIL)
I tried using
(while (a)
but it still gives me the same error
Message 4 of 17
ВeekeeCZ
Then try this...
Spoiler
(defun c:chtxt (/ ss i d)
  (if (setq ss (ssget "_x" '((0 . "*text"))))
    (repeat (setq i (sslength ss))
      (setq b (entget (ssname ss (setq i (1- i)))))
      (entmod (subst '(40 . 0.1)
		     (assoc 40 b)
		     b))))
  (princ)
and some notes for ya...
Spoiler
(setq ss (ssget "_x" '((0 . "*text*")))) ; second * not necessary
(setq a (ssname ss i))  ; still did not set i!
(setq i 0)		; move before the line above
(while (/= a NIL)       ; it's equal to: (while a
(setq b (entget a))
(setq b (subst '(40 0.1) (assoc 40 b) b)) ; needs to be '(40 . 0.1)
(entmod b)
(1+ i)			; you need to store it into i variable
(princ)
Message 5 of 17
hmsilva
Your code revised
(defun c:chtxt (/ ss i a b)
    (if (setq ss (ssget "_x" '((0 . "*text*"))))
        (progn
            (setq i 0
                  a (ssname ss i)
            (while (/= a nil)
                (setq b (entget a))
                (setq b (subst (cons 40 0.1) (assoc 40 b) b))
                (entmod b)
                (setq i (1+ i)
                      a (ssname ss i)
    (princ)
or, perhaps something like this
(defun c:demo (/ ent i ss)
    (if (setq ss (ssget "_x" '((0 . "*TEXT"))))
            (setq ent (entget (ssname ss (setq i (1- i)))))
            (entmod (subst (cons 40 0.1) (assoc 40 ent) ent))
    (princ)
Hope this helps,
Henrique
Message 6 of 17
Satoews
It amazes me how fast you guys can do that. 😃
Shawn T
Message 7 of 17
hmsilva
I was too slow....
@ВeekeeCZ beat me to it... 🙂
Henrique
Message 8 of 17
Ranjit_Singh
Great job and thanks for the help. I am still unsure why a simple while is giving me a nil error? Can someone explain please. Thanks.
Message 9 of 17
Satoews
because you set your i before a
(setq i 0)
and you didn't set your i in the while loop.
 (setq i (1+ i)
i think your lisp just kept running in loops.
Shawn T
Message 10 of 17
Ranjit_Singh
Thanks! silly me. rookie mistake
Message 11 of 17
Satoews
Keep at it! Maybe we can both be writing code like bee and hmsilva eventually 😃 When you have the time go over both hmsilvas and bee's code and look what they did to 1. fix your code and 2. optimize your code. and 3. how their codes differ from one another.
Shawn T
Message 12 of 17
ВeekeeCZ
@hmsilva wrote:
I was too slow....
Henrique
🙂 This time.
But it's not a rase! I would rather be if there was a button... something like "I am on it!"
Message 13 of 17
hmsilva
@ВeekeeCZ wrote:
@hmsilva wrote:
I was too slow....
Henrique
🙂 This time.
Of course it is not a race, the 'beat me' was just because your answer was posted a few seconds before mine, and if I had seen your answer, I wouldn't post mine, your answer was correct...
Cheers
Henrique
Message 14 of 17
Ranjit_Singh
Right! I will get there in a couple years (or decades maybe Smiley Wink) Here is my revised code with all improvements from everyones input. Thankyou all.
(defun c:chtxht(/ i a)
(setq i -1)
(while (setq a (ssname (ssget "_x" '((0 . "*text*"))) (setq i (1+ i))))
	(entmod (subst (cons 40 0.1) (assoc 40 (entget a)) (entget a)))
(princ)
Message 15 of 17
dbroad
Remember also
1) You don't need a program to do this.  CTRL+A selects everything.  In properties palette choose text.  Enter the text height.
2) These kinds of programs will not change the embedded text heights in mtext (where words/characters have size modifiers).
Architect, Registered NC, VA, SC, & GA.
Message 16 of 17
ВeekeeCZ
(setq i -1)
(princ)
- don't make a selection each time while it tests the condition!!! It could be different!!
- generally, in this kind of cases where you need to go throw the WHOLE selection set, it's better repeat function. You tell the repeat function how many cycles you need and no other test is required. In opposite to the while function, where is tested each run.
(defun c:chtxt (/ i a ss)
  (setq i -1
  (while (setq a (ssname ss (setq i (1+ i))))
    (entmod (subst (cons 40 0.1) (assoc 40 (entget a)) (entget a))))
  (princ)
Message 17 of 17
ВeekeeCZ
@hmsilva wrote:
@ВeekeeCZ wrote:
@hmsilva wrote:
I was too slow....
Henrique
🙂 This time.
Cheers
Henrique
Of course!!! I know how this works. 🙂 cheers
