Change size/position label - z-value lisp
infoH8EQN
Message 1 of 8
infoH8EQN
I would like to change the size and position of the label on this lisp.
Someone can help me, please?
Many Thanks
Postition: top-center from the point
(defun c:zpt ( / i p s )
   (if (setq s (ssget '((0 . "POINT"))))
       (repeat (setq i (sslength s))
           (setq p (assoc 10 (entget (ssname s (setq i (1- i))))))
           (entmake
               (list
                  '(000 . "MTEXT")
                  '(100 . "AcDbEntity")
                  '(100 . "AcDbMText")
                   (cons 1 (strcat "Z = " (rtos (cadddr p))))
                   p
   (princ)
Replies (7)
Message 2 of 8
ВeekeeCZ
HERE are codes you need.
Message 3 of 8
infoH8EQN
thanks for this.
I add top-center + text height + conversion in meter.
I have a problem with moving up by 210mm
the label. Should be the insertion point (code 20?) but doesn't work.
           (entmake
               (list
                  '(000 . "MTEXT")
				  '(40 . 140)
				  '(71 . 2)
                   (cons 1 (strcat  (rtos (/ (cadddr p) 1000.))))
                   p
   (princ)
This is what I get. In red what it should do.
Message 4 of 8
ВeekeeCZ
No, you will have to move the entire text. Use POLAR.
Why MTEXT, why top-middle?
I would prefer this
Message 5 of 8
infoH8EQN
Thanks. I found this Lisp in a forum, and it works very well but needed customization. My knowledge of the LISP language is limited, so I'm not sure how to implement a POLAR move.
Regard Mtext... It was Mtext on the original lisp. I don't know the reason for that.
Regard Top-Middle... because the final result should be similar to this:
Message 6 of 8
ВeekeeCZ
How does that differ from the screenshot I have posted?
Message 7 of 8
infoH8EQN
Your screenshot is perfect. I need help implementing it in Lisp. My attempt to implement the Polar Move function in Lisp failed. The syntax is incorrect.
           (entmake
               (list
                  '(000 . "MTEXT")
				  '(40 . 140)
				  '(71 . 2)
				   (command "._move" s "" "0,0,0" "@150<90")
                   p
   (princ)
Message 8 of 8
ВeekeeCZ
The move is a bad idea.
Version for your mtext which dose not make much sense to me and my text version.
(defun c:zpt-mtext ( / i p s )
      (entmake (list
		 '(000 . "MTEXT")
		 '(40 . 140)
		 '(71 . 2)
		 (cons 1 (strcat  (rtos (/ (cadddr p) 1000.) 2 2)))
		 (cons 10 (polar (cdr p) (/ pi 2) 210.))
  (princ)
(defun c:zpt-text ( / i p s )
      (setq p (cdr (assoc 10 (entget (ssname s (setq i (1- i)))))))
      (entmake (list
		 (cons 0 "TEXT")
		 (cons 10 p)
		 (cons 11 p)
		 (cons 40 140)
		 '(72 . 1)
		 '(73 . 1)
		 (cons 1 (strcat  (rtos (/ (caddr p) 1000.) 2 2)))))))
  (princ)
