Change Offset with lisp - Increase the space between multiple lines
Emi_Riv
Message 1 of 8
Emi_Riv
Hello everyone
I came across this, but it doesn't seem to work with AutoCAD 2018.
https://www.cadtutor.net/forum/topic/65407-increase-the-space-between-multiple-lines/
Does anyone have an alternative solution?
I've been searching for hours, but haven't found anything. =/
Thank you in advance for your assistance!
Best regards
Replies (7)
Message 2 of 8
Sea-Haven
Did you check the Exceed link also. Note the comments about removing the BBC color coding from the older code.
Arrange the wires with a constant offset - AutoLISP, Visual LISP & DCL - AutoCAD Forums (cadtutor.ne...
Message 3 of 8
Emi_Riv
Hi Sea
Thank you for your feedback.
Yes i saw it and tried it but doesn't work aswell. 😕
Also removed the BBC color from the first code which also didn't work.
Message 4 of 8
Emi_Riv
Doesn't anyone have an idea? Is Lisp working for anyone? I always need a lot of time for this process and would be happy if someone could help me with it.
Message 5 of 8
ВeekeeCZ
Try this one. It's the code from there with minor adjustments. It should work in 2018.
;; https://www.cadtutor.net/forum/topic/65407-increase-the-space-between-multiple-lines/?do=findComment&comment=539014
(defun c:test ( / foo s l i d e ) ; Increase the space between multiple vertical lines[/color]
  (defun foo (l n / i ls)
    (cons	(setq i (car l))
      (progn (repeat (1- (length l))
	       (setq ls (cons	(setq i	(if (> (cadr l) (+ n i))
					  (cadr l)
					  (+ n i)))
				ls))
	       (setq l (cdr l)))
	(reverse ls))))
  ;hanhphuc 19.06.2018
  (initget 7)
  (and
    (setq d (getdist "\nSpecify space distance : "))
    (setq s (ssget ":L" '((0 . "LWPOLYLINE"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    l  (cons (cons e (mapcar 'cdr (vl-remove-if '(lambda (x) (/= 10 (car x))) (entget e)))) l)))
    (setq l (vl-sort l ''((a b) (< (caaddr a) (caaddr b)))))
    (foreach x (mapcar '(lambda (a b) (foreach x '(2 3) (setq a (subst (list b (cadr (nth x a))) (nth x a) a))) a) l (foo (mapcar 'caaddr l) d))
      (entmod (append (vl-remove-if '(lambda (x) (= (car x) 10)) (entget (car x)))
		      (mapcar '(lambda (x) (cons 10 x)) (cdr x))))))
  (princ)
Message 6 of 8
Emi_Riv
Wow, it works, a thousand thanks. Is it possible to align not only vertical but also horizontal lines? And perhaps, can the spacing also be reduced? Currently, if the gap between two lines is 150, it cannot be reduced to 100. Of course, only if it's not too much trouble; I'm already happy to have this option now.
Message 7 of 8
ВeekeeCZ
This should do the trick. Any angle, any distance, can specify a no-move line.
(vl-load-com)
(defun c:LineSpacing ( / *error* doc s x p l f i a d q o)
  (or *pls-c* (setq *pls-c* 10)) ; default
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if doc (vla-endundomark doc))
    (princ))
  (and (princ "\nSelect polylines at segments to space, ")
       (setq s (ssget "_:L" '((0 . "LWPOLYLINE"))))
       (>= (sslength s) 2)
       (setq *pls-c* (cond ((getdist (strcat "\nSpecify offset <" (rtos *pls-c*) ">: "))) (*pls-c*)))
       (or (setq f (car (entsel "\nSpecify fix line : "))) t)
       (setq x (ssnamex s))
       (setq p (cond ((assoc 1 x) 		(cadr (last (assoc 1 x))))   		; last pointed selection
		     ((assoc 4 x)		(cadr (last (assoc 4 x)))) 		; first point of fence
		     ((minusp (car (last x)))	(mapcar '/ (apply 'mapcar (cons '+ (mapcar 'cadr (cdr (last x))))) '(4 4)))))
       (setq l (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
       (setq l (mapcar '(lambda (x) (list x (vlax-curve-getclosestpointto x p))) l))
       (setq l (vl-sort l '(lambda (x1 x2) (< (caadr x1) (caadr x2)))))
       (setq l (vl-sort l '(lambda (x1 x2) (< (cadadr x1) (cadadr x2)))))
       (setq f (cond (f) ((caar l))))
       (setq i (vl-position f (mapcar 'car l)))
       (setq l (mapcar '(lambda (x) (cons (- (vl-position x l) i) x)) l))
       (setq o (cdr (assoc 0 l)))
       (setq r (vlax-curve-getparamatpoint (car o) (cadr o)))
       (setq o (list (vlax-curve-getpointatparam (car o) (fix r)) (vlax-curve-getpointatparam (car o) (1+ (fix r)))))
       (not (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object)))))
       (foreach j l
	 (and (mapcar 'set '(i e p) j)
	      (setq r (vlax-curve-getparamatpoint e p))
	      (setq a (+ (/ pi 2) (angle '(0 0 0) (vlax-curve-getFirstDeriv e r))))
	      (setq a (rem a (* 2 pi)))
	      (setq a (if (< (* 0.75 pi) a (* 1.75 pi)) (+ pi a) a))
	      (setq d (entget e))
	      (setq q (reverse (cdr (reverse (vlax-curve-getpointatparam e (fix r))))))
	      (setq d (subst (cons 10 (polar (inters (car o) (cadr o) q (polar q a 1) nil) a (* i *pls-c*))) (cons 10 q) d))
	      (setq q (reverse (cdr (reverse (vlax-curve-getpointatparam e (1+ (fix r)))))))
	      (entmod d)))
  (*error* "end")
Message 8 of 8
Emi_Riv
This is a dream. A thousand thanks.
Really very beautiful.😀😊
