Change layer color to bylayer
msarqui
msarqui
Hi guys.
I am trying to create a function to change the color of layers:
(defun ModLayer (layname laycolor  / doc layers vlalay)
(setq	doc      (vla-get-ActiveDocument (vlax-get-acad-object))
	layers   (vla-get-Layers doc)
);setq
(setq vlalay (vla-item layers layname))
(if laycolor
	(vla-put-color vlalay laycolor)
(defun c:MLA () ;Change to magenta (ModLayer "0" 6) ;This works )
(defun c:MLA () ;Change to bylayer
(ModLayer "0" 256) ;This give an error: ; error: Automation Error. Invalid argument Color in IAcadLayer::put_Color
Any help please?
Marcelo
Kent1Cooper
Any help please?
A Layer cannot have ByLayer assigned to it as a color.  Only objects/entities can have ByLayer as their color assignment.  "ByLayer" means the color is taken from the Layer on which the object is drawn -- a Layer is not "drawn" on some [presumably other?] Layer.
I believe you would have the same trouble if you tried to assign "ByBlock" [color 0] to a Layer.
Kent Cooper, AIA
msarqui
Hi Kent,
I can see my mistake now.
Thanks for the explanation!
Marcelo
