Change in lisp to get E,N Coordinates added to CH
mint09
Message 1 of 8
mint09
hai, i need a small help.i have a working lisp routine which gives perpendicular line distance to main pline when clicked on a place perpendicular, all i want to add is the leader at the where i click and Easting and Northing and CH. and also instead of TEXT i need MText position where i can click. pls reply if its possible.
i've added a screenshot for reference ..... thanks
(defun c:Chi (/ s p c a d tp sch)
  (setq sch (getstring "\nSpecify start chainage : <0>"))			;"0" is set as the default value
  (if (= sch "")(setq sch "0"))
  (if
    (and (setq s (car (entsel "\nPick a polyline :")))
	 (or (= (cdr (assoc 0 (entget s))) "LWPOLYLINE")
	     (alert "Invalid object! Please pick a polyline only.")
     (while
       (and
	 (setq
	   p (getpoint "\nSpecify point perpendicular to polyline :")
	 (setq c (vlax-curve-getclosestpointto s p))
	 (setq a (angle p c))
	 (not (grdraw p c 1 -1))
	 ;; rubber line in red colour.
	 (setq d (angle	'(0. 0. 0.)
			(vlax-curve-getfirstderiv
			  s
			  (vlax-curve-getparamatpoint s c)
	 (or
	   (or (equal (rem (+ d (* pi 0.5)) (+ pi pi)) a 1e-4)
	       (equal (rem (+ d (* pi 1.5)) (+ pi pi)) a 1e-4)
	   (alert
	     "Picked point is not a perpendicular to picked polyline. <!>"
	 (setq tp (getpoint "\nSpecify Point for Text : "))
	(entmakex
	  (list
	    '(0 . "text")
	    '(100 . "AcDbEntity")
	    '(67 . 0)
	    '(370 . 13)
	    '(100 . "AcDbText")
	    (cons 10 tp)
	    (cons 40 0.6)		; Change text height here
	    (cons 1
		  (strcat "CH=" sch "+"
			  (rtos (vlax-curve-getdistatpoint s c) 2 3)			;3 instead of 4 to specify precision
	    (cons 71 0)
	    (cons 72 0)
	    (cons 11 '(0 0 0))
	    '(100 . "AcDbText")
	    (cons 73 0)
  (princ)
(vl-load-com)
Replies (7)
Message 2 of 8
mint09
can anyone help please?? i dont know how to change it.
Message 3 of 8
ВeekeeCZ
No wonder... No dwg, no help...
Try this...
(entmakex
	  (list
	    '(0 . "Mtext")
	    '(67 . 0)
	    '(370 . 13)
	    '(100 . "AcDbMText")
	    (cons 10 tp)
	    (cons 1
			  "\nE=" (rtos (car p) 2 3)
			  "\nN=" (rtos (cadr p) 2 3)
	    ;(cons 71 0)
	    ;(cons 72 0)
	    ;(cons 11 '(0 0 0))
	    ;'(100 . "AcDbText")
	    ;(cons 73 0)
Message 4 of 8
mint09
Thank you, its working well, Just one help if possible. how to add leader to it? i've tried to change it but keeps getting error..
this is what ive changed in it. pls check, i just want the texts with leader..
(defun c:Chin (/ s p c a d tp sch PTXT )
(entmakex
	  (list
	    '(0 . "Mtext")
	    '(67 . 0)
	    '(370 . 13)
	    (cons 10 tp)
	    (cons 1
		  (command "leader" p PTXT "" (strcat "CH=" sch "+"
			  "\nN=" (rtos (cadr p) 2 3) "")
	    ;(cons 71 0)
	    ;(cons 72 0)
	    ;(cons 11 '(0 0 0))
	    ;(cons 73 0)
Thanks @ВeekeeCZ
Message 5 of 8
dbhunia
Try this way.....
(setvar "cmdecho" 0)
  (if
     (while
       (and
	 (setq
			  s
	 (or
	   (alert
		(command "_.QLEADER" c p tp 1
				(strcat "CH=" sch "+" (rtos (vlax-curve-getdistatpoint s c) 2 3))
				(strcat "E=" (rtos (car p) 2 3))
				(strcat "N=" (rtos (cadr p) 2 3))
		(vlax-put-property (vlax-ename->vla-object (entlast)) 'height 0.6);;; Text Height 0.6
  (setvar "cmdecho" 1)
  (princ)
(vl-load-com)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 6 of 8
mint09
thanks, it is working but is it possible to change the leader vertex to 2? . its giving a 3 vertex leader and the leader line is starting from the centerline, not the line perpendicular where i pick. Please check the screenshot i have attached.
Thank you for all helps.. @dbhunia @ВeekeeCZ
Message 7 of 8
dbhunia
For.....
Change the line....
To.....
(command "_.QLEADER" p tp "" 1
Debashis Bhunia
Message 8 of 8
mint09
Thank you so much, its working perfect, saves me a lot of time.  Thanks a lot...
i've attached the lisp in case anyone gets it useful. it gives coordinates and chainage(perpendicular to chainage line).
