Change image_button background color in lisp
darkfprh
darkfprh
Hi I'm making an lisp with dcl.
and I want to display color and change it.
so I use image_button's background color.
But I can't change color in lisp.
So How can I display and change its color?
DCL)
:image_button{key=img_color; width=4; aspect_ratio=1;}
LISP)
(set_tile "img_color" col) <- But It's not answer...
hak_vz
(defun change_button_color ( / new_color)(setq new_color (acad_colordlg 1)) (set_tile "img_color" new_color))
(action_tile "img_color" "change_button_color")
(start_dialog)
Miljenko Hatlak
darkfprh
I tried it already. But It doesn't change color....
andkal
Try fill_image.
Example:
(defun DCL_FILLIMAGE (Im_key ClrIndex1 / )
    (start_image Im_key)
    (fill_image 0 0 (dimx_tile Im_key) (dimy_tile Im_key) ClrIndex1 )
    (end_image)
);defun
• www.autolisps.blogspot.com - Productivity plugins for Autocad and Autocad MEP
• Autodesk AppStore
pbejse
You may have to close the dcl and rebuild with a different color assignment to the image box
(defun _StartDia ( clr / f new_color dcl_id)
    (setq dcl_id (load_dialog "Dark.dcl"))
    (if	(not (new_dialog "Dark" dcl_id))
      (exit)
   (start_image "img_color")
    (fill_image 0 0 (dimx_tile "img_color") (dimy_tile "img_color") clr )
      (end_image)
    (action_tile "img_color" "(done_dialog 2)")
    (action_tile "accept" "(done_dialog 1)")
    (action_tile "close" "(done_dialog 0)")
    (setq f (start_dialog))
    (unload_dialog dcl_id)
;; you do the rest here for 1 and 0 ;;;
    (if (= f 2)
      (progn
       (_StartDia new_color)
like this
(_StartDia 1)
1 as initial color
HTH
hak_vz
Sorry for not instant reply I was out.
Please attach your DCL so we can see what you want to achieve.
In my previous code you should probably change ass follow but I have to guess what tile we are scripting.
to
(set_tile "img_color" (itoa new_color))
Miljenko Hatlak
darkfprh
Thank you But It doesn't work...
(set_tile "img_color" "1") -> change text
(set_tile "img_color" 1) -> wrong type argument error
