Change hatch transparency in nested blocks
Message 1 of 18
Hi guys,
I am new to lisp and I would like to know what line/s should I change on the lisp below to change the transparency of hatch in nested blocks. The code works perfectly in changing the hatch colour.
Thanks!
(defun c:HC ( / aDoc color)
     (vl-load-com)
     (setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
     (if (setq color (acad_colordlg 7 t))
         (progn
             (vlax-for blk (vla-get-blocks aDoc)
                 (if (and
       (eq :vlax-false (vla-get-islayout blk))
       (eq :vlax-false (vla-get-isxref blk))
   (vlax-for itm blk
       (if (eq  (vla-get-ObjectName itm) "AcDbHatch" )
           (vla-put-color itm color)
          (vla-regen adoc acActiveViewport)
    (princ)
Replies (17)
Message 2 of 18
phanaem
You only need to change (setq color (acad_colordlg 7 t)) to (setq color (getstring"\nSpecify transparency (0-90): ")) and vla-put-color to vla-put-entitytransparency ,and it would work, but you also need to check the input validity, so try this:
(defun c:HT ( / aDoc tr)
     (vl-load-com)
     (if
       (progn
         (initget 132)
         (setq tr (getint "\nSpecify transparency (0-90): "))
         (cond
           ((eq (type tr) 'int)
            (if (<= 0 tr 90) (setq tr (itoa tr)))
           ((eq (type tr) 'str)
            (or
              (wcmatch (strcase tr) "BYLAYER,BYBLOCK")
              (not (princ "\nInvalid value."))
         (if
           (and
           (vlax-for itm blk
             (if
               (eq (vla-get-ObjectName itm) "AcDbHatch")
               (vla-put-entitytransparency itm tr)
     (princ)
Message 3 of 18
Woah thanks! That's exactly what I am looking for!
Message 4 of 18
gavrielN5EPC
Observer
Observer
This does work perfectly, except I don't want the pause for user input. I always want 90 transparency. Is there anyone that can modify this so it automatically enters "90" for the transparency value, instead of pausing for user input?
Message 5 of 18
ronjonp
@gavrielN5EPC
;; Change this
;; to this
(setq tr 90)
Message 6 of 18
gavrielN5EPC
Observer
Observer
Perfection! Thank you!!!
Message 7 of 18
ronjonp
@gavrielN5EPC You could also use this .. it won't bomb on locked layers.
;; Changes hatch transparency in blocks to 90%
(defun c:ht (/ a d)
  ;; RJP » 2024-06-28
  (vlax-for l (vla-get-layers (setq d (vla-get-activedocument (vlax-get-acad-object))))
    (cond ((= -1 (vlax-get l 'lock)) (vlax-put l 'lock 0) (setq a (cons l a))))
  (vlax-for b (vla-get-blocks d)
    (if	(= 0 (vlax-get b 'isxref) (vlax-get b 'islayout))
      (vlax-for	o b
	(and (vlax-write-enabled-p o)
	     (= (vla-get-objectname o) "AcDbHatch")
	     (vla-put-entitytransparency o 90)
  ;; Relock layers
  (foreach l a (vlax-put l 'lock -1))
  ;; Regen to see changes
  (vla-regen d 1)
  (princ)
Message 8 of 18
gavrielN5EPC
Observer
Observer
Thank you very much. I unlock all layers as my second step in my "process", and the transparency is way down on the list, so layers are already unlocked at that time. However, I do have another challenge for you, if you're up to it? I have a lisp routine (BG.lsp) that contains a bunch of commands and runs other lisp routines. Can you create a lisp routine that I can run, which will prompt me to browse to a folder containing multiple .dwg files, and then run my main "BG" lisp routine on all dwgs without me having to open each dwg? I have had that working years ago, but I lost it along the way.
Message 9 of 18
ronjonp
Have a read here. No need for me to reinvent the wheel 8-)
Message 10 of 18
gavrielN5EPC
Observer
Observer
Thank you, but my brain doesn't work that good 😞 I tried creating an .scr file with the following, but I get a message saying "Invalid file name"
_.open **.dwg* _.BG _.save _Y _.close
Message 11 of 18
ronjonp
Try this syntax: _.open *file* (c:bg) _.save _Y _.close
Message 12 of 18
gavrielN5EPC
Observer
Observer
Thank you, but I'm still getting the same message. It doesn't even bring up the "browse for folder" dialog box. As soon as I double click the scr file to run it, I get that "Invalid file name" message 😞
Message 13 of 18
gavrielN5EPC
Observer
Observer
I'm actually using *file* in my script. Maybe that needs to be changed to something specific for my task? But I just want to be prompted by a "browse for folder" dialog box and select the folder that I want to run my "BG.lsp" for all dwgs in that folder. The folder will change constantly, so that is why I need the "browse for folder" option.
Message 14 of 18
ronjonp
It sounds like you have not loaded Lee's code. After you've done that run 'wscript' and use the line above.
Message 15 of 18
gavrielN5EPC
Observer
Observer
I have not loaded that code. How do I do that? I went to both links, but I don't see specific instructions on how to load that code.
Message 16 of 18
ronjonp
Sorry. I'm not sure how to give you any more help. Lee's "How to Run an AutoLISP Program" page is very detailed.
Download this:
Then follow his instructions.
Message 17 of 18
sergi_triado5JXV7
Community Visitor
Community Visitor
Hi guys, can you help me with a Lisp to modify the "bylayer" transparency of block shading? Thanks.
Message 18 of 18
ronjonp
@sergi_triado5JXV7  Can you post a sample drawing with before and after?
