Change Dimension Text Override and Layer
I want to dimension nearest to perpendicular and change the text override to "<>\PROW" and make sure it's on layer "P-Dim"
Here is what I have so far.
(defun c:dn()
(command "dimaligned" "nea" pause "per"pause
pause
(princ))
I know we would have to use this command below for the next portion but I don't know how to implement the rest.
 (command "dimedit" "n"
Can someone help with changing the text override and layer? I'm new to lisp routines.
Thanks for the help!
Satish_Rajdev
Use VL functions for that, For example :-
(defun c:test ( / d)
  (vl-load-com)
  (command "dimaligned" "nea" pause "per" pause pause)
  (if (and (setq d (vlax-ename->vla-object (entlast)))
	   (wcmatch (vla-get-objectname d) "*Dimension")
    (progn
      (vla-put-layer d "0")			; Add Layer Here
      (vla-put-textoverride d "ADD TEXT")	; Add Text Here
  (princ)
Best Regards,
Satish Rajdev
REY Technologies | Linked IN | YouTube Channel
@Satish_Rajdev
That's awesome thank you so much!
I wonder, is it possible to have a multiline dimension by incorporating \P or \X into the test override?
ADD\PTEXT
Satish_Rajdev
Yes. It's possible. For Example :-
(vla-put-textoverride d "ADD\PTEXT")
(vla-put-textoverride d "ADD\XTEXT")
If you want to join 2 different variables from it use strcat function, For example :-
(setq a "ADD")
(setq b "TEXT")
(vla-put-textoverride d (strcat a "\P" b))
(vla-put-textoverride d (strcat a "\X" b))
Best Regards,
Satish Rajdev
