Change dim style + current layer
Temssi.d
Temssi.d
I need a lisp script that changes the current dim style and layer,
after selecting a specific object.
thanks
;Set to current dimstyle by picking an object on desired dimstyle.
(defun C:SetC ()
   (prompt "\Select Desired Dimstyle...")
   (command "-DIMSTYLE" "_R" "")
;change the layer to the last object selected using "LAYMCUR"
   (princ)
ВeekeeCZ
LAYMCUR does not accept "last object selected". Besides - we only have "previous" type of selection available but it holds objects (= selection set) not a single object (= entity).
(defun C:SetC ( / e)
  (setq e (car (entsel "\nSelect dimension: ")))
  (command "-DIMSTYLE" "_R" "" e)
  (command "LAYMCUR" e)
  (princ)
Kent1Cooper
ADDSELECTED will do both those things for you without any code, and call up a Dimensioning command [presumably you don't need to change those settings unless/until you want to make more Dimensions].  You can also use the MM command in MakeMore.lsp, >here<, which in addition offers you options to make a New Dimension of the same type anywhere you want, or apply the DIMCONTINUE or DIMBASELINE command springing from the selected Dimension.
Kent Cooper, AIA
Temssi.d
WOW
