Change copy mode in lisp
Nathan_Tigner
Message 1 of 8
Nathan_Tigner
Hi guys,
This is probably a stupid question and is easy to fix but I havn't found the answer yet.
I use a lisp for some command shortcuts so I don't ever have to edit the pgp file that comes with cad.
One of them is (defun c:C() (command "COPY")), yes, I have one for circle since I am replacing the default C for circle. My question is, doing it this way puts the copy command in displacement mode, how would I switch it to multiple mode in the lisp?
Replies (7)
Message 2 of 8
ВeekeeCZ
This way you often launch an older version (LISP) of the command than the current one (AutoCAd). Yes, there are many differences.
So I would recommend getting back to PGP. It serves pretty well its purpose.
If you really need it, usually you can use the (initcommandversion) predecessor. But it's not always working...
Message 3 of 8
Kent1Cooper
How 'bout this?
(defun C:C (/ ss)
  (if (setq ss (ssget))
    (command "_.copy" ss "" "_multiple")
Kent Cooper, AIA
Message 4 of 8
Nathan_Tigner
Boom. Thank you so much!
Message 5 of 8
john.kaulB9QW2
I don't see what's wrong with:
(defun C:c ()
  (command "_.copy") )
But if you're evaluating on to start the copy command or not with IF, wouldn't you just use vl-cmdf (because vl-cmdf evaluates each argument before passing the command to AutoCAD, the invalid selection set is detected, and the command is not executed.)?
(defun C:c ()
  (vl-cmdf "_.copy" (ssget) "_multiple") )
another swamper
Message 6 of 8
Kent1Cooper
(defun C:c ()
But if you're evaluating on to start the copy command or not with IF, wouldn't you just use vl-cmdf (because vl-cmdf evaluates each argument before passing the command to AutoCAD, the invalid selection set is detected, and the command is not executed.)? ....
Message 1 explains what's wrong with your first code window -- that's the OP's whole point.
Your (vl-cmdf) needs object selection to be concluded in order to work:
(defun C:C ()
  (vl-cmdf "_.copy" (ssget) "" "_multiple")
But it's not where my mind goes first, having done this so long before that function existed....
Kent Cooper, AIA
Message 7 of 8
john.kaulB9QW2
Yes, those quotes are needed (I must have been too ambitious in my typing).
Understood.
NOTE: when using that if-construct you are used to, I was always taught to use a "boolean variable". So instead of typing
(if (setq ss (ssget...)
the proper syntax is:
(setq selectionset (ssget))
(if selectionset
because it offers greater readability; -i.e. the symbol nil in lisp has at least three different jobs.
1. to represent an empty list. '()
2. falsity. (= 1 0)
3. failure.
because the proper syntax is being less ambiguous. In other languages, that if-construct you are using can lead to bigger problems.
another swamper
Message 8 of 8
ВeekeeCZ
Sort of generic solution is using (initcommand...) but  in general it is more convenient to use the pgp file for this job.
(defun c:c () (initcommandversion) (command "_.copy") (princ))
