change color to all layers
f_rivaXGG6C
f_rivaXGG6C
i would need to change the color of all layers that have several colors into one (specifically color 252) using a lisp command (i need to integrate it into a larger command), do you know how to do this?
thank you very much for your help
pendean
Community Legend
Community Legend
What did you try so far? the commandline sequence is quite straight forward
-LAYER
COLOR
252
<enter>
... how would you like to address those objects that have color overrides and ignore layer colors?
LDShaw
Something like?
;;; Lisp Name: foo
;;; Author: Lonnie
;;; Date Created: 2024-08-06
;;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/change-color-to-all-layers/td-p/12942402
;;; Last Edited: [Insert Last Edit Date]
;;; DESCRIPTION:
;;; A routine to change the color of all layers in the current AutoCAD drawing
;;; to a specified color.
;;; Usage:
;;; 1. Load the Lisp routine.
;;; 2. Run the command "FOO" in AutoCAD.
;;; Parameters:
;;; color - The color number to apply to all layers.
;;; Returns:
;;; None
;;; Notes:
;;; - This routine changes the color of all layers in the current drawing to the
;;;   specified color.
;;; ---------------------------- Main program --------------------------------;
(defun c:foo (/ color layer)
  (vl-load-com)
  (setq color (getint "\nEnter the color number to apply to all layers: "))
  (vlax-for layer (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
    (vla-put-color layer color)
  (princ (strcat "\nAll layers have been changed to color " (itoa color) "."))
  (princ)
This won't change everything to by layer and hardly addresses blocks but
f_rivaXGG6C
I had tried "_ai_selall" and "_all", it did not even remotely occur to me to use "*" to select which layers to change
those that have the override, i used the setbyalayer command
f_rivaXGG6C
this solution is also interesting, which I will try to understand how it works and probably use in the future.
but for what I am doing now, the solution offered above is more straightforward.
thank you very much for the alternative solution
