Change color of selected objects with dialogbox
Angelswing91
Angelswing91
Hi all,
i tried to change color of selected objects (not layer) with dialogbox... it appers, but nothing changes. 😞
(defun c:spa ()
(if
(setq p1 (cadr (ssgetfirst)))
(progn (sssetfirst) (setq p1 (acad_colordlg 5 t)))
(princ)
Can somebody help me?
Kent1Cooper
@Angelswing91 wrote:
…. i tried to change color of selected objects (not layer) with dialogbox... it appers, but nothing changes....
You are simply changing what the 'p1' variable contains from a selection set to a number, rather than applying  that as a color number to  that selection set.  And nothing will happen if there is no pre-selection.  Try something like this [untested]:
(defun c:spa (/ p1)
  (if
    (setq p1 (cond ((cadr (ssgetfirst))) ((ssget))))
      ; if there's anything pre-selected, use it; otherwise, ask for selection
    (progn
      (sssetfirst) ; clear selection/grip/highlight
      (command "_.chprop" p1 "" "_color" (acad_colordlg 5 t) "")
    ); progn
  ); if
  (princ)
); defun
Kent Cooper, AIA
dlanorh
(defun c:spa ( / cdrs sel c el)
  (defun cdrs (dxf lst) (cdr (assoc dxf lst)))
  (cond ( (setq sel (entsel "\nSelect Entity : "))
          (setq c (acad_colordlg 5 t) el (entget (car sel)))
          (if (cdrs 62 el) (entmod (setq el (subst (cons 62 c) (assoc 62 el) el))) (entmod (setq el (append el (list (cons 62 c))))))
        (t (princ "\nNothing Selected"))
  (princ)
I am not one of the robots you're looking for
pbejse
I like to think there's more to this than just changing colors, why else would you not use toolbar or ribbon? Select object and ..
Please tell us more.
@dlanorh
FWIW You dont need all this
(if (cdrs 62 el)
This would be enough regardless 62 exists or not
	 (entmod (append el (list (cons 62 c))))
HTH
