change circle size...
bibleje
bibleje
I would like to change the diameter of all the circles of a drawing (several hundred) from one diameter to another.  I haven't use LISP in a long long time so I am needing a jump starter here.  Would someone please get me started?  Thank you.
In Him
John E. Bible
AutoCad 2017
ВeekeeCZ
Here you are.
(defun c:CircleDiameter ( / ss d ed )
  (if (and (setq d (getdist "\nNew diameter: "))
	   (setq d (/ d 2.))
	   (setq ss (ssget "_:L" '((0 . "CIRCLE"))))
    (repeat (setq i (sslength ss))
      (setq ed (entget (ssname ss (setq i (1- i)))))
      (entmod (subst (cons 40 d)
		     (assoc 40 ed)
		     ed))))
  (princ)
ВeekeeCZ
Or one more for ACADs 2011+, a bit shorter.
(defun c:CircleDiameter ( / ss d)
	   (setq d (/ d 2.))
      (setpropertyvalue (ssname ss (setq i (1- i))) "Radius" d)))
  (princ)
bibleje
Excellent!  Thank you sir.
Kent1Cooper
You can also do that without a routine, using QSELECT to find either all  Circles, or all Circles of a specific radius or diameter, or all Circles of less than or more than a designated radius or diameter, and then collectively change their radii or diameters to the same desired value in the Properties palette.
Kent Cooper, AIA
