Visual LISP, AutoLISP and General Customization
Change attribute text size of multiple attributes in multiple blocks
7 REPLIES 7
Message 1 of 8
b_worland
500 Views, 7 Replies
Hi All,
Would any one have a lisp or could create a lisp that could change attribute text heights, of all attributes, of selected blocks in a drawing?
Problem  - I have a drawing that has multiple blocks. Each block has multiple attributes with the same and different attribute names.  All the attributes for each block are aligned vertically (see drawing attached and snapshot below). I would like to be able to select some blocks, enter a new attribute text height and have all attributes of the selected blocks change their attribute text height. I understand the lisp will also have to change the vertical separation between the attribute text so they can be read. If the vertical separation doesn't change and the attribute base point stays the same this could mean the text would overlap with the other attributes in the vertical stack and be unreadable.
I don't want to change attribute text height by selecting attributes individually or one block at a time . I just want to select some blocks or every block in then have all attributes for every selected block change.
The drawing with blocks and attributes is attached.
So, would anyone have or be able to create a lisp that could allow for -
1. User runs lisp. Lisp prompts for selection of some or all blocks (including ability to use previous selection set or select similar)
2. Lisp then selects all attributes of every selected block
3. Lisp prompts user to enter a new attribute text height.
4. Lisp changes all attribute text heights and maintains readability of the attributes in the vertical stack relative to each other.
Snapshot of "readability" of attributes that are vertically stacked prior to changing text height. The same "readability" is needed after the change to text height.
I wish i had some programming knowledge but I don't. Any help appreciated.
Kind Regards
Ben
Labels (1)
7 REPLIES 7
Message 2 of 8
Sea-Haven
in reply to: b_worland
Bit rough and very little testing.
(defun c:attsc ( / obj atts att pt ht sc x xp y yp)
(setq obj (vlax-ename->vla-object (car (entsel "\nSelect a block object "))))
(setq atts (vlax-invoke obj 'Getattributes))
(setq x 0.0 y 0.0)
(foreach att atts
  (setq pt (vlax-get att 'Insertionpoint))
  (setq xp (car pt) Yp (cadr pt))
  (setq x (+ x xp) Y (+ y yp))
(setq x (/ x (length atts)) y (/ Y (length atts)))
(setq pt (list X y))
(setq ht (vlax-get (car atts) 'height))
(setq sc (/ (getreal "\nEnter new height ") ht))
(foreach att atts
  (command "scale" (vlax-vla-object->ename att) "" pt sc)
(princ)
Message 3 of 8
komondormrex
hey there,
in most simple terms
(defun c:atts_change_height (/ insert_sset height att_list scale_point scale_factor)
	(if (setq insert_sset (ssget '((0 . "insert") (66 . 1))))
		(progn
			(setq height (getreal "\nEnter desirable heigth for all attributes: "))
			(foreach insert (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex insert_sset))))
				(setq att_list (vlax-invoke insert 'getattributes)
					  scale_point (mapcar '+ (list 0 (vla-get-height (car att_list)) 0)
					  						 (vlax-get (car att_list) 'insertionpoint)
					  scale_factor (/ height (vla-get-height (car att_list)))
				(mapcar '(lambda (attribute) (vla-scaleentity attribute (vlax-3d-point scale_point) scale_factor))
						 att_list
	(princ)
Message 4 of 8
ec-cad
in reply to: Sea-Haven
Hmm.
That seems to scale the entire block ?
ECCAD
Message 5 of 8
b_worland
in reply to: komondormrex
Hi K,
Thanks very much, that works perfectly.
I just want to say how fantastic this forum is. People like yourself, Sea-heaven and all others, extremely generous with your knowledge and time.
Thanks again
Ben
Message 6 of 8
b_worland
Hi Sea-haven,
Thank you for sending this through. I couldn't quite get it to work, but Komondormrex has sent a solution in.
As I said in my reply to komondormrex, generous people, like yourself, make this a great forum.
Ben
Message 7 of 8
Sea-Haven
in reply to: ec-cad
There are numerous blocks but I looked for one that matched and it seemed to work.
Note the "X" has not changed which would have been the block scaling.
Message 8 of 8
komondormrex
your welcome)
AutoCAD Inside the Factory
