Change attribute in a selected block
Message 1 of 8
I am having a problem with a part of my code. In this part, (i made it so that you can run independently) it asks you the block to change and the attribute value to change. Unfortunately, it says that there's too few arguments when I give the input.
Here's the code:
(defun c:abc (/ b l blk layertable layname)
(setq blk (entsel "\nSelect block to modify: "))
(initget (+ 1 2 4))
(setq b (getreal "\nNew att value? (>0;1<)"))
;open layer (setq LayerTable (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) (if (and (tblsearch "LAYER" "MC_BLOCK") (setq layname (vla-item layertable "MC_BLOCK")) (= (vlax-get-property layname 'lock) :vlax-true) ) (vla-put-lock layname :vlax-false)) ;change attribute (setq l (cons (cons "CAMPO_6" (itoa (fix b))))) ;close layer (setq LayerTable (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) (if (and (tblsearch "LAYER" "MC_BLOCK") (setq layname (vla-item layertable "MC_BLOCK")) (= (vlax-get-property layname 'lock) :vlax-false) ) (vla-put-lock layname :vlax-true)) (princ) )
Thanks in advance
Replies (7)
Message 2 of 8
cadffm
CONS need TWO arguments..
The blue cons get just one argument..
http://help.autodesk.com/view/OARX/2020/DEU/?guid=GUID-5424079C-26CD-4E7D-819A-DE7B7B340077
Sebastian
Message 3 of 8
Ajilal.Vijayan
The error happens because of this line
remove the first cons from this line.
Edit:
Is the code you posted is complete ?
Because the posted code does not modify the attribute value and the below mentioned variable is not used anywhere.
(setq l)
Message 4 of 8
Thanks, that helped 🙂
But it's still not operational.
This is the full code i put together for this task:
(defun c:abc (/ b l blk i layertable layname)
(setq blk (entsel "\nSelect blocks to modify: "))
(initget (+ 1 2 4))
;open layer
	;modify attribute
	(progn
	(setq l (cons "CAMPO_6" (itoa (fix b))))
	(LM:SetAttributeValues (ssname blk  l))
	;close layer
  (princ)
(defun LM:SetAttributeValues ( blk lst / enx itm )
    (if (= "ATTRIB" (cdr (assoc 0 (setq enx (entget (setq blk (entnext blk)))))))
        (if (setq itm (assoc (strcase (cdr (assoc 2 enx))) lst))
            (progn
                (if (entmod (subst (cons 1 (cdr itm)) (assoc 1 enx) enx))
                    (entupd blk)
                (LM:SetAttributeValues blk lst)
Message 5 of 8
SeeMSixty7
Ok it look like you are getting close to what you want, but you have a few issues with proper arguments you are passing to functions.
You don't need to enclose the attribute section in a progn code block.
the LM:SetAttributeValues function takes an entity  and a list of attribute tag and value pairs
should look like this (LM:SetAttributeValues (car blk) (list l))
You had specified an ssname function with blk as the argument. your blk is a listed selection point and entity name. (car blk) pulls out the entity name from the list.
your l variable (BTW use something that doesn't look like a 1 for a variable name)
is constructed properly but the function is looking for a list of dotted pairs.
Here is some updated code, hopefully this helps.
(initget (+ 1 2 4))
;open layer
	;modify attribute
	;close layer
  (princ)
            (progn
                    (entupd blk)
Message 6 of 8
Thanks a lot, its working... well almost. It is updating the attribute, but only in integer values. I type 0.75, it updates to 0. If I put 2.5, it updates to 2. Since I want to input values between 0 and 1 this is indeed problematic.
If I update the block manually it has no problems in accepting real numbers.
Message 7 of 8
cadffm
You should stop it and starts to learn each (for you) new lispfunction from scratch.
(itoa (fix b))
Read more about FIX (AutoLISP)
then read more about itoa and RTOS and DIMZIN
Sebastian
Message 8 of 8
SeeMSixty7
you are using FIX function. That is what that does.
(fix number)
number
Type: Integer or Real
A numeric value.
Return Values
Type: Integer
If you want to use a real value use RTOS function
Example
(setq l (cons "CAMPO_6" (rtos b 2 2)))
