Change all Dimension style text fill color to background and bring all dimensions draworder to front
anton_chmidt
anton_chmidt
Is this possible to do with a lisp? Would be great if it would do it to all dim styles and aligned dimensions too. Without changing any other settings.
If someone can help me that would be great
ВeekeeCZ
Try this.
(defun c:DimStylesAllBackground ( / :AllNonXrefDimstyles s)
  (defun :AllNonXrefDimstyles (s / d r n)
    (while (setq d (tblnext s (null d)))
      (if (not (wcmatch (setq n (cdr (assoc 2 d))) "*|*"))
	(setq r (cons n r))))
    r)
  (foreach e (:AllNonXrefDimstyles "dimstyle")
    (setpropertyvalue (tblobjname "dimstyle" e) "Dimtfill" 1))
  (setvar 'Dimtfill 1)
  (if (setq s (ssget "_X" '((0 . "DIMENSION"))))
    (command "_.draworder" s "" "_front"))
  (princ)
anton_chmidt
This is perfect thank you very much!
Also I wanted to make sure it only changes text background and no other dim properties, so made dimstyle comparison before and after lisp. Indeed only difference was "Text background enabled". So it is working perfectly
