Change 2 first characters fo Mtext
Hi masters!!
As the title says i want to change the 2 first characters of a Mtext.
The selection of those Mtexts will be:
(setq Mset (ssget "X" '((0 . "*text")(1 . "*c/*"))))
I really dont know how to continue.
Thanks in advance!
dlanorh
Perhaps by telling us how you want to change them?
I am not one of the robots you're looking for
I want to change the 2 first characters for "1"
dlanorh
  (cond (Mset
          (repeat (setq cnt (sslength Mset))
            (setq ent (ssname Mset (setq cnt (1- cnt)))
                  elst (entget ent)
                  txt (strcat "1" (substr (cdr (assoc 1 elst)) 3))
            (entmod (subst (cons 1 txt) (assoc 1 elst) elst))
That worked!
Thank you so much!
dlanorh
You have a small error in your ssget statement.
this will select text with "c/" anywhere in the text string, but will still change the first two characters. To select "c/" only at the start change your ssget to
(setq Mset (ssget "X" '((0 . "*text")(1 . "c/*"))))
Its ok. First 2 characters are 2 numbers and it follows with c/. And i want to change those characters for 1.
Thanks for your help!!
