Center Line Symbol
Center Line Symbol
Would anyone know of a method, using Visual Lisp, that would alow me to
insert a center line symbol block to an existing dimension line and allow it
to be rotated and scaled to the dimensions properties? Any help would be
greatly appreciated!
Mark
Replies (16)
lsp to insert centerline block? Make a block and insert into dimension
line that has been exploded. Or do you want centerline symbol to insert
in centerline? Do you want font that has centerline symbol?
Walt,
Sorry for the confusion. I basically would need to insert a block below the
dimension value similar to what is shown on the attached file. I already
have the block I'm just looking for a quick way to insert the block on a
selected set of dimensions.
Mark
"Walt Engle" wrote in message
news:4923114@discussion.autodesk.com...
Not a problem. To have dim text above and below dim line, us *\X * and
the following text will be below dim line. MUST USE UPPER CASE X.As soon
as I can, I will find the shx file that has the CL symbol.
Walt,
I'm aware of the formatting to get text below or above a dimension line.
This is an older font the company would like to keep using. When using plain
text all that is needed to get the CL string, for this particular font, is
to type %%130. The problem is that this formatting does not work with mtext
(which dimensions use) so my work around is to use a block. I'm just having
trouble finding the right "vla" functions to get the needed info from the
dimensions to account for rotation, etc.
Mark
news:4923125@discussion.autodesk.com...
Ok - here's something you can do: use Romansx5.shx. The code for CL
symbols is \U2104. So, you can copy and paste "\X\U2104 to \U2104"
(without the quotes) to add to your edited dim text. Example: if your
dimension is 5", edit it so that it reads 5"\X\U2104 to \U2104. I am
attaching romansx5.dwg as a zip file.
attaching
Attaching
I understand. I too have a font that mtext doesn't like but the font I
sent (shp, dwg and shx) is a Romans font and you can use \U2104.
hmsilva
Hy Mark
Try this...
\U+2104
Cheers
Henrique
Walt,
I have to keep the same font so your solution using the "romans" font will
not work. I would like to use the block route for now. Do you have any
suggestions on what "vla" functions to use?
Mark
news:4923181@discussion.autodesk.com...
Hmsilva,
All I get when using your suggestion is a ?.
Mark
wrote in message news:4923311@discussion.autodesk.com...
Hy Mark
Try this...
\U+2104
Cheers
Henrique
What font are you using?
I suspect that the reason Mtext won't work is that the font is not encoded
as a unicode font.
If you recompile it into a unicode font, the CL symbol will work correctly.
See Help on unicode fonts.
I've written a utility that helps convert non unicode fonts to unicode
fonts.
If you would like me to try to recompile the font as a unicode font, post
your shx file and let me know.
P.S. Recompiling the font as unicode won't change the appearance of the
font. It just adds functionality for Mtext. It still works and looks the
same in Text (DText) objects.
Thanks Allen! Please find attached the font for your use.
Mark
"Allen Johnson" wrote in message
news:4923411@discussion.autodesk.com...
as a unicode font.
fonts.
See if this can get you where you want to go. Once you select a dimension, then it will search for the block that is associated with that dimension, and print the name of the text style. You can change it to do what you want once you get the text object because then you can find out where it is and the angle so that you can add your block in the right location.
Tim
(defun c:DimText (/ ActDoc BlkCol tmpEnt tmpEntData BlkName Blk TxtObj)
; Prints the name of the text style of the selected dimension.
(vl-load-com)
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(setq BlkCol (vla-get-Blocks ActDoc))
(if
(and
(setq tmpEnt (entsel "\n Select dimension: "))
(setq tmpEntData (entget (car tmpEnt)))
(= (cdr (assoc 0 tmpEntData)) "DIMENSION")
(progn
(setq BlkName (cdr (assoc 2 tmpEntData)))
(setq Blk (vla-Item BlkCol BlkName))
(vlax-for Obj Blk
(if (= (vla-get-ObjectName Obj) "AcDbMText")
(setq TxtObj Obj)
(prompt (strcat "\n Text style name is: " (vla-get-StyleName TxtObj)))
(princ)
We use some arch... fonts (archquik.shx, architxt.shx and archtitl.shx)
that we bought from a now-defunct company called Digital Architect
Software. They are really nice architectural hand-lettering fonts, with
centerline, property line, delta, diameter, and stacked fraction
characters, etc., but they are the old decimal-encoded fonts and they
don't
display correctly when used in Mtext (they still work as Dtext, go
figure...).
I could furnish you the shp or shx files -- do you think you'd want to
extend that offer to us, too? It'd be awesome to get control of these
fonts in mtext.
TIA,
Randy Benson
"Mark" wrote in message
news:4923475@discussion.autodesk.com...
Mark
encoded
as a unicode font.
correctly.
fonts.
the
Woops -- I replied to Mark when I meant to ask you to extend your offer
of recompilation to Archquik, Architxt and Archtitl (oh, and the mono-
versions, if possible). I bought them all years ago from 'Digital
Architect Software', now defunct.
Thanks again (still) In Advance,
Randy Benson
encoded
as a unicode font.
correctly.
fonts.
post
the
