Cant Rotate Text
Cant Rotate Text
HR2323
Message 1 of 12
Cant Rotate Text
HR2323
i am trying to rotate text at zero angle but it is not work. please see attachment drawing and please give me lisp to set text zero rotation.
Replies (11)
Message 2 of 12
devitg
Find attached lisp The main fact is the NORMAL property
Message 3 of 12
ВeekeeCZ
Not sure if a lisp helps you... texts are in 3 different planes.
I isolated texts, used flatten, then changed the angle of rotation to 0.
Message 4 of 12
devitg
Did you test my LISP ?
Message 5 of 12
ВeekeeCZ
Sorry devitg, I did not. I judged prematurely. Your routine works perfect.
Message 6 of 12
devitg
Thanks for testing it . It is glad to know the work has been tested an be useful, and better if a bug is noticed , to fix it. As ever, this task help me to understand about VARIANT and SAFEARRAY , and also about ALIGNMENT , Insertion Point and TEXTALIGNMENTPOINT
Message 7 of 12
HR2323
Thank you very much to all of you to reply, especially Thanks to devitg for the lisp file.
Message 8 of 12
HR2323
i am facing another problem please download dwg file and see polyline, block.
Message 9 of 12
HR2323
I used a Flatten command but there is some problems. The name of the block is different shows.
Message 10 of 12
ВeekeeCZ
Sorry man, not following you... I used FLATTEN on TEXTs only. Don't see any block name problem.
If you having problems with FLATTEN then use devitg's routine.
Message 11 of 12
devitg
What is the problem , or the task to do? By the way, where are you? I´m at Córdoba, Argentina
Message 12 of 12
phas50
You have to set the rotation angle after selecting either single line text of Multiline text. This is the sequence: Select Text or in the command bar type text, specify starting point of the text, next specify rotation angle, set this to 360 click enter, write your text, select the rotate command or type rotate, select text and it will rotate 360 degrees.
