09:04 AM
Hello, I am starting to learn how to work with autolisp but I'm having a really hard time. Hope you can help me because I have few questions.
1. I want to assign (don't know if this word is correct in this context) value.
For example:
In math it is
H=30; R=0.35H
But how do you write this in LISP language? (setq R (* 0.35 H) ?
I have an example by which I made my assignment but I still don't get it.
Here is my assignment and here is what came up with. maybe you could tell me the main things and tell where the mistakes are.
; baseline data: p0, L, H, b, c, a, w, a1
;--baseline data----------------------------
(defun prduom ()
(setq p0 (getpoint "\n mark base point p0:"))
(setq L (getdist "\nWidth L <30>:"))
(if (null L) (setq L 30))
(setq H (getdist "\nHeight H <30>:"))
(if (null H) (setq H 30))
(setq b (* [0.35] H)
(setq c (* [0.15] H)
(setq a (* [0.85] H)
(setq r (* [0.35] H)
(setq a1 (- L a)
(setq W (getdist "\nPolyline width W <0.5>:"))
(if (null w) (setq w 0.5))
(setq m (getdist "\nScale m <1.0>:"))
(if (null m) (setq m 1.0))
;--evaluating coordinates-------------------------
(defun skaic ()
(setq p1 (polar p0 (/ pi 2.0) H))
(setq p2 (polar p1 0 a1))
(setq p3 (list (car p2) (- (cadr p2) c)))
(setq p4 (polar p3 (* 1.75 pi) (* r (sqrt 2))))
(setq p5 (polar p4 0 c))
(setq p6 (polar p5 (* 1.75 pi) (* r (sqrt 2))))
(setq p7 (list (car p6) (- (cadr p6) b)))
;--drawing contour------------------------------
(defun braiz ()
(command "PLINE" p0 "w" w "" p1 p2 p3 "ARC" "ANGLE" "-90" p4 "L" p5 "ARC" "ANGLE" "90" p6 "L" p7 p0 "")
(setq p2 (entlast))
(command "SCALE" p2 "" p0 m )
(setq PL2 (entlast))
(command "hatch" "ansi31" 2 0 PL2 "")
;--Main Program-------------------------------------------
(defun C:uzdv()
(prduom)
(skaic)
(braiz)
(princ)
Edited by
Discussion_Admin
note please use the insert code option when post to the community
