Cannot invoke (command) from *error* without prior call to (*push-error-using-command*). Converting (command) calls to (command-s) is recommended. AutoCAD2021
jrauRM2PM
Message 1 of 16
jrauRM2PM
Attached is a Smash command that worked in AutoCAD 2018 but when now that I am using AutoCAD 2021 it does not work. I'm new to AutoCAD lsip programs and I'm not sure what needs updated.
Replies (15)
Message 2 of 16
Moshe-A
@jrauRM2PM  hi,
fixed 🤣
enjoy
moshe
Message 3 of 16
jrauRM2PM
Thank you for your help. I'm still getting an error though, probably something I did?
Command: malformed list on input
Command:
Command:
Command:
Command: smash no function definition: VDPW_SMASH_MAIN
Command:
Message 4 of 16
ronjonp
@jrauRM2PM The code loads fine for me.
_$
C:SMASH
VDPW_SMASH_MAIN
VDPW_SMASH_ERRORHANDLER
nil
; 5 forms loaded from #<editor "<Untitled-6> loading...">
Message 5 of 16
Kent1Cooper
You can simply do what it recommends.  Any (command) function(s) inside the *error* handler should be converted by having the -s added to the end of the function name.
Kent Cooper, AIA
Message 6 of 16
Moshe-A
@jrauRM2PM
did you touch the code?
try the attched
Message 7 of 16
jrauRM2PM
Error: no function definition: VDPW_SPIN
Message 8 of 16
Moshe-A
@jrauRM2PM ,
(vdpw_spin) is a missing function (probably lay in other lisp file), go back to who gave this for complete set 😀
Moshe
Message 9 of 16
jrauRM2PM
Thak you!
Message 10 of 16
Kent1Cooper
@jrauRM2PM wrote:
Thak you!
[Notice that your tha[n]k-you shows as being in Reply to yourself.  That means you must have used the "Reply to the topic..." slot below the last Message.  Everything entered there always shows as if it's in Reply to Message 1, including the to-whom part.  Instead, always use the REPLY "box" toward the bottom right of the specific Message you're actually Replying to.]
Kent Cooper, AIA
Message 11 of 16
jrauRM2PM
Sorry, I have no idea what I need. I have an AutoCAD Customization Guidebook I just started reading. Other than that I have 0 experience with coding.
Message 12 of 16
Moshe-A
how \ from where did you get this lisp?
Message 13 of 16
jrauRM2PM
I'm not sure where it came from. It was on our computers when I started here.
Message 14 of 16
Kent1Cooper
Then if it ever worked, the vdpw_spin function definition must also have been on them, somewhere.  Might the problem just be with its folder location?  If you can Search for content in text files, look for something containing that, we would hope in a file with a .lsp filetype ending.  But if it's in a compiled variety of file like .fas or .vlx, you won't be able to find it that way.  Could there be something about the file name that relates to its purpose?
Kent Cooper, AIA
Message 15 of 16
Kent1Cooper
A further question:  Since that missing function appears to be triggered only for "Polyline" [not "LWPolyline"] objects [which can be "heavy" 2D Polylines, 3D Polylines, or meshes], if you use it in a situation without any of those, does it work correctly?
Kent Cooper, AIA
Message 16 of 16
jrauRM2PM
Yes, it does appear to work.
