Cannot get coordinates pointes of a polyline
Kh.mbkh
Kh.mbkh
Im using this functions to get coordinates pointes of a ployline:
(defun PointsOfPline(Pline)
  (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget Pline)))
but it doesnt work with this p-line, because after calling (entget) the list starting with "10" is: (10 0 0 0) ??
(My pline here called B5Am)
rkmcswain
Without trying it or looking too carefully at the code, my guess would be this is written for LWPOLYLINE entities, and the one in your screenshot is a POLYLINE entity. See Also
Kh.mbkh
thank you that was a good remark
Kh.mbkh
It works with this now :
(defun PointsOfPline(Poline)
  (if (/= (cdr (assoc 0 (entget Poline))) "LWPOLYLINE")
  	(command "_convert" "_p" "_s" Poline "" )
  (mapcar 'cdr
	    (entget  Poline)
Kent1Cooper
If you want to get the vertices without converting a "heavy" Polyline to "lightweight," you can do this:
(defun PointsOfPline (pline / n vertices)
  (repeat (setq n (+ (fix (vlax-curve-getEndParam pline)) (if (vlax-curve-isClosed pline) 0 1)))
    (setq vertices (cons (vlax-curve-getPointAtParam pline (setq n (1- n))) vertices))
  ); repeat
  vertices
); defun
Kent Cooper, AIA
