- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In our office we have a logon script that copies the "Acaddoc.lsp from a server to the support path
"C:\Program Files\Autodesk\AutoCAD XXXX\Support". This works in all of the versions of AutoCAD that we use on the Windows 7 OS.
When we logon to a Windows 10 PC the file (for AutoCAD 2018) does not copy due to some security setting in the OS. Is there another support folder that this file can be copied to? We tried to copy the file manually by copying and pasting; we get the following errors in the screen shot below when we do this. The files can be copied to the desktop and then from there to the support path. We really want this automated in some way since we have a large number of AutoCAD desktops. Does anyone have any solutions to this?
Thanks in advance.
Copying the Ffle manually by using copy and Paste
Although the network location is available I get this error when trying to copy directly. The file can be copied to the desktop and then to the support path though.
