Can't get the "AddDimRadial" method to work
Hi all,
I am trying to modify the DMP lisp which I found here (also attached). I need to replace AddDim3PointAngular method with AddDimRadial method at line no. 203 of the code.
In brief the DMP lisp add dimension to plines with a single click which is really cool. But the code has been written in a way to add arc length whereas I would like to have arc radius instead.
So this is what the code does at the moment:
And this is what I need:
The error I get is:
Error: lisp value has no coercion to VARIANT with this type:  #<variant 8197 ...>
Can someone help me with the correct syntax?
It's difficult to do the task with your current code. Because it allows to select only Polylines. And retrieving radius of Polyline arc is not possible as far as I know. Here I have attached a separate code for ARC.
(defun c:adm ()
(vl-load-com)
(defun *error* (msg)
 (princ msg)
 (princ)
);defun error
(setq ss (ssget "_:S:E:L" '((0 . "ARC"))))
(setq obj (ssname ss 0)
      obj1 (vlax-ename->vla-object obj)
      cen (vla-get-center obj1)
      al (vla-get-arclength obj1)
      cp (vlax-3d-point (vlax-curve-getPointatDist obj1 (/ al 2))))
(vla-addDimRadial (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))) cen cp 5)
);defun
STM
hmm... Never thought that way. Thanks for enlightening.
joselggalan
Con permiso de autor del programa.
Updated file attached
Remove and add code:
                       ;;Code Removed:
			;;;(setq dm (vla-adddim3pointangular
			;;;	 acsp
			;;;	 (vlax-3d-point cen)
			;;;	 (vlax-3d-point y)
			;;;	 (vlax-3d-point z)
			;;;	 (vlax-3d-point txp)
			;;;(vla-put-textoverride
			;;;dm
			;;;(rtos (abs (- (vlax-curve-getdistatpoint pl y)
			;;;	      (vlax-curve-getdistatpoint pl z)
			;;;      2
			;;;      2
		      ;;Code new:
		      (setq dm (vla-AddDimRadial
				 acsp
				 (vlax-3d-point cen)
				 (vlax-3d-point mid)
				 0.0
