Can't get my lisp to show on toolbar
Markeckert
Message 1 of 32
Markeckert
I have the tool bar below with a cuix containing a VBA app.
I'm trying to add the CID.lsp file to that tool bar. I've created a CID.cuix for the CID.lsp file. I can't get the CID.cuix added to the tool bar. Can someone give me some guidance on what I need to do?
Replies (31)
Message 21 of 32
paullimapa
At command prompt enter CUILOAD and if you see BatchMe listed, select it and click Unload
Paul Li
IT Specialist
@The Office
Message 22 of 32
paullimapa
the other place to look for cui files that causes AutoCAD to load automatically at startup is under here:
C:\ProgramData\Autodesk\ApplicationPlugins\The Office Script Magician.bundle
Perhaps there's a folder here that's trying to load batchme.cuix
Paul Li
IT Specialist
@The Office
Message 23 of 32
Markeckert
Thanks, That got rid of the batchme reference but I still can't get the button for the Change Issue Date. I added it to the GridTool but it doesn't seem to be showing. I also have all three buttons in the Grid.mnu.
Message 24 of 32
Markeckert
I think I have it working. Thanks for your help!!.
Message 25 of 32
paullimapa
Looks like you're missing this step:
Paul Li
IT Specialist
@The Office
Message 26 of 32
paullimapa
glad you got it working now...cheers!!!
Paul Li
IT Specialist
@The Office
Message 27 of 32
Markeckert
Do I need the grid.mnu file if I'm using a grid.cuix file? I guess I'm not clear on what the mnu file does?
Message 28 of 32
Markeckert
Message 29 of 32
paullimapa
Both mns & mnu were old ways of creating AutoCAD menus.
Now AutoCAD uses cuix and the compiled version is mnr
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-9EF6BC00-4C90-47CB-BF93-6FC382FA9E81
Paul Li
IT Specialist
@The Office
Message 30 of 32
Sea-Haven
My $0.05 comment and starting to many years ago with mnu is that it is so much easier using notepad than trying to use CUI. I have made mnu using lisp to write bulk code regarding programs to be called, cuts down creation time. The cuix is a ZIP file and you can look inside and you will see the xml files making up your menu.
Yep back to convert say a mnu file to a XML file, then zip to a CUIX. Looking at say create contents in Excel. Using lisp to read Excel make XML and yes lisp can zip files.
Message 31 of 32
paullimapa
True, the mnu & mns days were pretty easy to edit using a regular text editor.
But since Autodesk went with the Ribbon GUI, the cuix took over.
Paul Li
IT Specialist
@The Office
Message 32 of 32
Sea-Haven
Yes the ribbon is not supported via a mnu. But that is why I have for too long looked at make a ribbon from plain text, converting to xml. The xml is a repeating pattern have a look. I need to bring it to the top of my "To do" say remake a  custom ribbon, from a Notepad file.
