Can't figure out what is wrong with this LISP
Message 1 of 23
hi, everyone,
I wrote a lisp myself but the lisp telling bad ssget list. how to resolve it. I was trying so much time but i can't figure out my problem. could anyone solve me?
thanks advance to everyone
hussain
(defun c:cl ()
(setq ss (ssget '((0 "insert"))))
(setq slen (sslength ss))
(setq index 0)
(repeat slen
(setq ab (entget (ssname ss index)))
(setq ac (cdr (assoc 10 ab)))
(setq p1 (getpoint ss))
(setq p2 (getpoint "\nenter another point: "))
(setq ang (angle p1 p2))
(command "line" p1 p2 "c" "")
(setq index (1+ index))
(princ)
Accepted solutions (3)
Replies (22)
Message 2 of 23
ВeekeeCZ
@Anonymous wrote:
hi, everyone,
hussain
(defun c:cl ()
(setq ss (ssget '((0 . "insert")))) ; missing dot
(setq index 0)
(repeat slen
;(setq p1 (getpoint ss)) ; did you meant to use the ac point?
(setq ang (angle ac p2)) ; what are you going to do with angle?
(command "line" "_non" ac "_non" p2 "c" "") ; "c is wrong, what that should be for?" turn off osnaps as well
(princ)
Message 3 of 23
dbhunia
Hi
@Anonymous wrote:
hi, everyone,
hussain
(defun c:cl ()
(setq index 0)
(repeat slen
(princ)
The highlighted line would be...
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 4 of 23
thank you so much beekeecz for your email.
i meant the angle. the line wants to draw at 45 degrees then goes a straight line again - 45 degrees to connect other blocks(kindly see the image). this is i want to do it but i can't draw a line to connect to block as i attached the image .
thanks
hussain
Message 5 of 23
ВeekeeCZ
THIS is a very similar issue that came up recently, might be inspirational to you as well.
I'll try look into this one too...
I saw no 45° on the image. Would you send a dwg with a suggested connection for any angular situation? (any different than an ideal horizontal)
Message 6 of 23
hi beekeecz
I attached the drawing here. kindly find below.
Message 7 of 23
dbhunia
Try this ...... (For this particular Block).......Because your line Start & End point of line is not at the base point of the Block....
(defun C:JB (/ p1 p2 p3 p4 p5 ang ang_r h1 h2)
(setq osm (getvar "osmode"))
(command "cmdecho" 0)
(command "osmode" 0)
(cond ((= 2 (sslength ss))
	(Setq P1 (cdr (assoc 10 (entget (ssname ss 0)))))
	(Setq P1 (list (nth 0 P1) (+ 0.2 (nth 1 P1)) (nth 2 P1)));;;;;;;;;;;;
	(Setq P2 (cdr (assoc 10 (entget (ssname ss 1)))))
	(Setq P2 (list (nth 0 P2) (+ 0.2 (nth 1 P2)) (nth 2 P2)));;;;;;;;;;;;
	(Setq P3 (getpoint "\nPick Point for Horizontal Line: "))
	(setq ang (getangle "\nEnter Angle: "))
	(setq ang_r (- ang (/ pi 2)))
	(setq a1 (distance p1 (list (nth 0 P1) (nth 1 P3) (nth 2 P3))))
	(setq h1 (/ a1 (cos ang_r)))
	(setq b1 (* h1 (sin ang_r)))
	(setq a2 (distance p2 (list (nth 0 P2) (nth 1 P3) (nth 2 P3))))
	(setq h2 (/ a2 (cos ang_r)))
	(setq b2 (* h2 (sin ang_r)))
	(Setq P4 (polar P1 (angle p1 (list (nth 0 P2) (nth 1 P1) (nth 2 P2))) b1))
	(Setq P4 (list (nth 0 P4) (nth 1 P3) (nth 2 P4)))
	(Setq P5 (polar P2 (angle p2 (list (nth 0 P1) (nth 1 P2) (nth 2 P1))) b2))
	(Setq P5 (list (nth 0 P5) (nth 1 P3) (nth 2 P5)))
	(command "_.pline" p1 p4 p5 p2 "")
    ((> 2 (sslength ss)) (princ "\nMinimum two Blocks need to select."))
    ((< 2 (sslength ss)) (princ "\nMore than two Blocks selected."))
(command "osmode" osm)
(command "cmdecho" 1)
(princ)
Debashis Bhunia
Message 8 of 23
ВeekeeCZ
Sorry, busy on a training.
If your blocks are horizontally aligned, this simple approach will cover it.
(defun c:OffConnect ( / p1 p2)
  (if (and (setq p1 (car (entsel "\nLeft block: ")))
           (setq p1 (trans (cdr (assoc 10 (entget p1))) 0 1))
           (setq p2 (car (entsel "\nRight block: ")))
           (setq p2 (trans (cdr (assoc 10 (entget p2))) 0 1))
    (command "_.pline"
             "_from" p1
"_none" "@0,0.2" "_none" "@0.3,-0.6" "_none" (strcat "@" (rtos (- (distance p1 p2) 0.6) 2 4) ",0") "_none" "@0.3,0.6" "")) (princ) )
Message 9 of 23
hi dbhunia
thank you so much dbhunia for creating me.
1.may i know why you add this function(sin and cos). it is very hard to understand.
2.why you add 0.2? what is the reason?
Message 10 of 23
dbhunia
@Anonymous wrote:
hi dbhunia
In your drawing you want the line starts above 0.2mm from the insertion point of the Block so I added that value with Y co-ordinate (as your Block has been placed in 1:1 scale) only keeping the other X,Z Co-ordinates of P1 & P2 as it is....
This is not the only way to get Y co-ordinate with  0.2mm offset from the insertion point of the Block .......
Debashis Bhunia
Message 11 of 23
hi beekeez
thanks a lot, you and dbhunia.both are doing very great job.i appreciate your effort.
thanks
hussain
Message 12 of 23
    (command "_.pline"
             "_from" p1
hi beekeecz
you created this AutoLISP for only horizontal side only. how about another side, I mean vertical (left side & right side).i modified your lisp but i did not get actually what i wanted to do.,although it little helps to me. kindly check this.i want to make the line by selected block to vertically (right and left side) which i marked red colour.i hope you understand everything. I appreciate you what to do for me.
(defun c:blrr ( / p1 p2)
;(setq p1 (car (entsel "\nLeft block: ")))
(setq p1 (trans (cdr (assoc 10 (entget (ssname ss 0)))) 0 1))
;(setq p2 (car (entsel "\nRight block: ")))
(setq p2 (trans (cdr (assoc 10 (entget (ssname ss 1)))) 0 1))
(command "_.pline"
"_from" p1
"_none" "@0,0.0"
"_none" "@-0.6,0.6"
"_none" pause
"_none" pause
p2
(princ)
Message 13 of 23
ВeekeeCZ
It's not difficult, just simple math.
(defun c:OffConnect (/ ss p1 p2 pt ag)
  (if (and (setq ss (ssget '((0 . "INSERT"))))
           (setq ag (angle p1 p2))
    (command "_.pline"
             "_none" (setq pt (polar p1 (+ ag (/ pi 2)) 0.2))
             "_none" (setq pt (polar pt (- ag (/ pi 3)) 0.8))
             "_none" (polar pt ag (- (distance p1 p2) 0.8))
             "_none" (polar p2 (+ ag (/ pi 2)) 0.2)
  (princ)
Message 14 of 23
    (command "_.pline"
  (princ)
thank you so much.
this is, I am really trying to get this last 3days to work myself, but the result is the only get frustration then I post here to get advice those who familiar in the AutoLISP program. I am so happy. I deeply appreciate your help. could i have your email id?
how about more than 2 blocks by selecting ssget . it just adds again (i mean setq p1, setq p2 and setq p3 etc...) to get more block. here, where will add "while" expression to get automatically connect the block with a line.
Message 15 of 23
ВeekeeCZ
@Anonymous wrote:
... how about more than 2 blocks by selecting ssget . it just adds again (i mean setq p1, setq p2 and setq p3 etc...) to get more block. here, where will add "while" expression to get automatically connect the block with a line.
The issue is the workflow. Figure out HOW would you determine the order. If you select them one by one, it's obvious. If they are in a straight line, it's obvious... But what if they are not. Think like a programmer...
Message 16 of 23
 you wrote the message above.i can understand little by little, but not completely.
anyway, the order is, either it could be a straight line or vertical line. this is my expectation from you.
i tried again your code with few modifications, but the message pops up  "bad argument 2d/3d point". i attached here modification code. i know sure it's wrong.
(setq sa (sslength ss))
(setq i 0)
(repeat sa
(setq sb (cdr (entget (ssname ss i))))
(setq sc (car(assoc 10 sb)))
(setq i (1+ i))
;(setq p1 (trans (cdr (assoc 10 (entget (ssname ss 0)))) 0 1))
;(setq p2 (trans (cdr (assoc 10 (entget (ssname ss 1)))) 0 1))
(setq ag (angle sc sb))
(command "_.pline"
"_none" (setq pt (polar sc (- ag (/ pi 2)) 0.0))
"_none" (setq pt (polar pt (+ ag (/ pi 3)) 0.8))
"_none" (polar pt ag (- (distance sc sc) 0.8))
"_none" (polar sc (+ ag (/ pi 2)) 0.0)
(princ)
Message 17 of 23
ВeekeeCZ
(setq i 0)
(repeat sa
(setq i (1+ i))
(command "_.pline"
(princ)
You've probably meant something like this.
  (setq i -1)
  (repeat (1- (sslength ss))
    (setq i (1+ i))
    (setq p1 (trans (cdr (assoc 10 (entget (ssname ss i)))) 0 1))
    (setq p2 (trans (cdr (assoc 10 (entget (ssname ss (1+ i))))) 0 1))
    (command "_.pline"
             "_none" (setq pt (polar p1 (- ag (/ pi 2)) 0.0))
             "_none" (polar p2 (+ ag (/ pi 2)) 0.0)
  (princ)
If you run into trouble, try the "Fence" selection method.
Message 18 of 23
(setq i 0)
(repeat sa
(setq i (1+ i))
(command "_.pline"
(princ)
  (setq i -1)
    (setq i (1+ i))
    (command "_.pline"
  (princ)
hi beekeez
Alhamdulillah, thank you so much, you are a marvelous man.I deeply appreciate your helpHeartHeartHeart.
this is i really looked for 1 month.it is so amazing.
Message 19 of 23
hi beekeecz
sorry again to ask so many times. i have been using your lisp since you modified for me, even though this i really helping me.
my question is how about to connect line for the perpendicular side. i attached the image for you understand.
  (setq i -1)
    (setq i (1+ i))
    (command "_.pline"
  (princ)
Message 20 of 23
hi beekeecz
kindly reply me for my queries
