Can lisp calculate and draw with reference to formulae ?
smallƑish
Message 1 of 18
smallƑish
I have an Equation to find the Duct reducer length. Can Lisp calculate it and draw the reducer automatically?
Accepted solutions (3)
Replies (17)
Message 2 of 18
Kent1Cooper
AutoLisp can certainly calculate that.  The length of the reducer would be:
(+ (* 1.73 (abs (- w1 w2))) 70)
[I used (abs) so that it doesn't matter whether w1 or w2 is the greater width.]
Having it draw that is another issue, but should be possible.  But questions arise:
Is the transition always flush on one side as in your example, or might transitions occur narrowing or widening on both sides?
Should it shorten the [in your example] bottom line on the right or on the left, or [for example] always the one on the narrower-duct side, or both equally, or...?
[I think we can assume that ducts will run in all directions, not always horizontally.]
What would be your expected procedure?  Call the command, and then....  Pick existing things?  Draw it all from scratch?  Etc.
Consider using a Dynamic Block.
Kent Cooper, AIA
Message 3 of 18
smallƑish
Ans : Both Side
Ans: Bigger side is Constand, Narrow side should adjust its length with reference to the equation
Ans : Horizontal, Vertically aligned etc
Ans;
Call cmd.
Pick Outer side of Main duct
Pick Inner side of Main duct
Pick Outer side of Sub duct
Pick Inner side of Sub duct
Then connect it by Lisp
No dynamic block
Suggested CMD Name
SRAD For side Reducer
ERAD for Equal Reducer
Message 4 of 18
Sea-Haven
When you pick  "Outer side of Main duct" make sure nearest is used
When you pick "Inner side of Main duct" make sure Perp is used
A bit of test code
(defun c:wow ( / )
(setvar 'osmode 512)
(setq pt1 (getpoint "\nPick outer side main duct "))
(setvar 'osmode 128)
(setq pt2 (getpoint pt1 "\nPick inner side main duct "))
(setq d (distance pt1 pt2))
(setvar 'osmode 47)
There are other methods that can be used for getting correct distance with slack object picking.
Message 5 of 18
smallƑish
I am sorry to tell you that, I m just started to learn lisp.
I Don't have any idea what, I have to do with the test code.
Message 6 of 18
kajanthangavel
Try this
(defun c:reducer (/ txt1 txt2 p1 p2 svnames r_len side)
(if (not (tblsearch "LAYER" "Reducer"))(command "-layer" "m" Reducer "p" "p" Reducer "c" 2 Reducer ""))
(if (setq txt1 (vla-get-TextString (vlax-ename->vla-object (car (entsel "\nPick text 1st value")))))
(princ (strcat "\nPipe 1 -" (rtos (atof txt1))))
(if (setq txt2 (vla-get-TextString (vlax-ename->vla-object (car (entsel "\nPick text 2nd value")))))
(princ (strcat "\nPipe 1 -" (rtos (atof txt2))))
(or side (setq side "ONE"))
(initget "ONE TWO")
(if (setq tmp (getstring  (strcat "\nType of reducer [ONE / TWO]  <" side ">: ")))
    (setq side tmp)
(setq p1 (getpoint "\nSpecify place point: "))
(setq svnames '(osmode cmdecho) svvals (mapcar 'getvar svnames))
(mapcar 'setvar svnames '(0 0))
(setq txt1 (atof txt1) txt2 (atof txt2))
(cond
	(	(eq side "ONE")
		(setq r_len (+ (* 1.73 (abs (- txt1 txt2))) 70))
		(princ r_len)
		(LWPoly
			(list
				(polar p1 (DTR 270) txt1)
				(polar p1 (DTR 0) 0)
				(setq p2 (polar p1 (DTR 0) r_len))
				(polar p2 (DTR 270) txt2)
		1
	(	(eq side "TWO")
		(setq r_len (+ (* 0.87 (abs (- txt1 txt2))) 70))
		(princ r_len)
		(setq p2 (polar (polar p1 (DTR 270) (/ txt1 2)) (DTR 0) r_len))
		(LWPoly
			(list
				(polar p2 (DTR 90) (/ txt2 2))
				(polar p2 (DTR 270) (/ txt2 2))
		1
(mapcar 'setvar svnames svvals)
(princ)
(defun DTR (a)(* PI (/ a 180.0)))
(defun LWPoly (lst cls)
  (entmakex (append (list (cons 0 "LWPOLYLINE")
                          (cons 100 "AcDbEntity")
                          (cons 100 "AcDbPolyline")
                          (cons 8 "Reducer")
                          (cons 90 (length lst))
                          (cons 70 cls);flag for polyline type 0 = open 1 = closed
                    (mapcar (function (lambda (p) (cons 10 p))) lst)
Message 7 of 18
smallƑish
Wow, It's an amazing trick. Loved it. Thank you very much.
I just wanted to inform you two points.
Any chance to auto-trim or extend the Sub duct to fix with the reducer end?
Is that possible to Type "O" Instead of One & "T" for Two (for a faster workflow)
Again Thank you very much for making the process easier than what I have requested.
Message 8 of 18
smallƑish
Also, I m facing issues with aligned objects.
Message 9 of 18
kajanthangavel
Now,
It works angle line and Polyline.
and you can input O & T
 I can not understand with  "Sub duct" , If you upload your drawing, I can try to fix it.
Message 10 of 18
smallƑish
Thank you very much for the updated lisp.
what I mean by the subduct, when we insert the reducer there will be a gap bw reducer and a smaller duct. Is there any automation possible to extend it till the reducer that we have made?
in the ss i have marked it by yellow polyline
Message 11 of 18
smallƑish
one more question, If the one-side reducer is on the bottom side, can we include any mirror option in the lisp?
Message 12 of 18
smallƑish
I found this “EE” LISP somewhere internet since I am using this for a long time, I am very familiar with and very good use this. As I am a very beginner to LISP. I can't understand what kind of logic is used in this. Still, I wish to ask if you can modify this LISP for our reducer purpose.
(defun c:EE()
(setvar "osmode" 512)
(prompt "\nPick Outer Side of Main Duct: ")
(setq en1: (entsel))
(prompt "\nPick Inner Side of Main Duct: ")
(setq en2: (entsel))
(prompt "\nPick Inner Side of Branch Duct: ")
(setq en3: (entsel))
(prompt "\nPick Outer Side of Branch Duct: ")
(setq en4: (entsel) CFM:M 1)
(setvar 'osmode 5375 )
(M:EE EN1: EN2: EN3: EN4: CFM:M 1 r_o_d:1)
(DEFUN M:EE (EN_:1 EN_:2 EN_:3 EN_:4 CFM:B? EN?:1 r_o_d:)
(setq r_o_d: 0.75)
(setq rod:d (- r_o_d: 0.5))
(setq x "en1:" EN_:1 (m:LSPR EN_:1))
(setq x "en2:" EN_:2 (m:LSPR EN_:2))
(setq x "en3:" EN_:3 (m:LSPR EN_:3))
(setq x "en4:" EN_:4 (m:LSPR EN_:4))
(setq pos: (inters en3:p1 en3:p2 en2:p1 en2:p2)
     pos: (if pos: (inters en3:p1 en3:p2 en2:p1 en2:p2)
                   (inters en3:p1 en3:p2 en2:p1 en2:p2 nil)
(setvar "lastpoint" pos:)
(setq dum:1 (osnap en1:pp "perp")
      dum:2 (osnap en4:pp "perp")
      wMAN: (distance pos: dum:1) W1 (/ WMAN: (/ CFM:M CFM:B?))
      w2 (distance pos: dum:2)
      rd:x (max w1 w2) rd:n (min w1 w2)
      a:1 (angle pos: en2:pp)
      a:2 (angle pos: en3:pp)
      a:2p (angle pos: dum:2)
      a:1p (angle pos: dum:1)
      ang:1 (- a:2 a:1) ang:12 (/ ang:1 2)
      dum:1 (abs (* rod:d rd:x (/ (cos ang:12) (sin ang:12))))
      en2:pp (polar pos: a:1 dum:1)
      en3:pp (polar pos: a:2 dum:1)
      arc:1 (polar en2:pp a:1p (- (* rod:d rd:x)))
      en1:pp (polar en2:pp a:1p w1)
      en4:pp (polar en3:pp a:2p w2)
      rd:2 (+ (* rod:d rd:x) (* (+ (* rd:x (cos ang:1)) rd:n) (sin ang:12) (/ 1 (cos ang:12)) (/ 1 (sin ang:1))))
 m: (if (minusp (- a:2p a:1p)) (setq m: 1) (setq m: -1))
arc:2 (if (< w1 w2) (polar en4:pp a:2p (- rd:2)) (polar en1:pp a:1p (- rd:2)))
 drw:a (* (atof (angtos (abs (- a:2p a:1p)))) m:)
(if (> (abs drw:a) 180) (setq drw:a (* (- 360 (abs drw:a)) (- m:))))
(setq pos:1 (inters en1:p1 en1:p2 en4:p1 en4:p2)
      pos:1 (if pos:1 (inters en1:p1 en1:p2 en4:p1 en4:p2)
                      (inters en1:p1 en1:p2 en4:p1 en4:p2 nil)
(m:odif en_:2 a:1 en2:p1 en2:p2 en2:pp pos:)
(m:odif en_:3 a:2 en3:p1 en3:p2 en3:pp pos:)
(IF EN?:1 (m:odif en_:1 a:1 en1:p1 en1:p2 en1:pp pos:1))
(m:odif en_:4 a:2 en4:p1 en4:p2 en4:pp pos:1)
(if (< w1 w2) (command "pline" en1:pp en2:pp "a" "ce" arc:1 "a" (- drw:a) "l" en4:pp "a" "ce" arc:2 "a" drw:a "l" "cl")
(command "pline" en4:pp en3:pp "a" "ce" arc:1 "a" drw:a "l" en1:pp "a" "ce" arc:2 "a" (- drw:a) "l" "cl")
(if (< w1 w2) (setq a: a:2p) (setq a: a:1p))
(IF (= MVAN:? "ON")(M:VANE))
(defun m:lspr (entt:)
(setq y (car entt:))
(set (read (strcat x "p1")) (cdr (assoc 10 (entget y))))
(set (read (strcat x "p2")) (cdr (assoc 11 (entget y))))
(set (read (strcat x "pp")) (cadr entt:))
(setq xp1 (car  (cdr (assoc 10 (entget y))))
      yp1 (cadr (cdr (assoc 10 (entget y))))
      xp2 (car  (cdr (assoc 11 (entget y))))
      yp2 (cadr (cdr (assoc 11 (entget y))))
(if (not (> (abs (- xp1 xp2)) 0.00001))(progn
    (setq xpp xp1 ynpp (cadr (cadr entt:))))
(progn
    (setq slpp (/ (- yp2 yp1) (- xp2 xp1))
          bpp  (- yp1 (* slpp xp1))
          xpp  (car (cadr entt:))
          ynpp (+ (* slpp xpp) bpp)
(set (read (strcat x "pp")) (list xpp ynpp))
(setQ X Y)
(defun m:odif (entt: ang: p1 p2 p3 p4)
(setq entt: (entget entt:))
(IF (or (= (rtos (angle p4 p3) 2 4) (rtos (angle p4 p1) 2 4)) (= (rtos (angle p4 p3) 2 4) (rtos (- (angle p4 p1) pi pi) 2 4))) (setq ch:1 p1 ch:2 p3) (setq ch:1 p2 ch:2 p3))
(if (and (= (rtos (angle p4 p1) 2 4) (rtos (angle p4 p2) 2 4)) (< (distance p4 p1) (distance p4 p2))) (setq ch:1 p2))
(setq entt: (subst (cons 10 ch:2) (cons 10 p1) entt:)
      entt: (subst (cons 11 ch:1) (cons 11 p2) entt:)
(ENTMOD ENTT:)
Message 13 of 18
ronjonp
@smallƑish Maybe try a trial of THIS.
Message 14 of 18
ronjonp
@smallƑish I posted some code for your other elbow question at CadTutor.
Message 15 of 18
komondormrex
check this.
Message 16 of 18
smallƑish
OMG!!!!!!!!!!!
How did you do that... It's unbelievable.. and working like a dream.
thank you very very much
Message 17 of 18
smallƑish
I don't know how to say thanks.
Still again Thanks a lot
Message 18 of 18
smallƑish
As I m shocked to see the reducer program. I wish to request you. Can we do the same for Elbow also, the same as attached video with EE program? In a single selection of 4 lines. Instead of selecting L1,L2,L3,L4.
