Call function c:Beta from within function c:Alpha
saitoib
saitoib
Hi all.
It's a little late for this, but...
Is it possible to call function c:Beta from within AutoLisp's my function c:Alpha?
Thank you.
Saitoib
diagodose2009
You try this code (C:Beta) or (command "C:Beta")
hak_vz
You can have in your code
(defun alfa (.... / .....) )
(defun beta (.... / .....) )
(defun c:alfa nil (alfa))
(defun c:beta nil (beta))
And in alfa you call function beta
(c:beta) or (beta ... ...)
C functions don't have arguments
Miljenko Hatlak
pbejse
@saitoib wrote:
Hi all.
Thank you.
Sure it is possible,
Real question is, what is the intention? are you planning to continue where Alpa command left off or right after what the main program finished with its task?  It can be a sub rather than a main function, especially if the program requires input from the user or a variable as an argument [ selecion set, string ...]
As an example
(Defun c:Alpha ()
  ; some functions ;
  (setq string (_Alpha&Beta (getstring "\nTell me something")))
  ;  more here ;
 (Defun c:Beta ()
  ; some functions ;
  ;  more here ;
(defun _Alpha&Beta (str)
  (princ (strcat "\nDo a lot of formating with this ---> " str))
  (princ)
HTH
saitoib
I needed to use c:.
I was able to solve the problem with (command (c:Beta)).
Thank you very much.
Saitoib
CodeDing
@saitoib , you do not need the (command ...) call. The propper way to call it is without. Like so:
(defun c:ALPHA ( / )
  (alert "This is Alpha.")
(defun c:BETA ( / )
  (c:ALPHA)
  (alert "This is Beta.")
Just better practice to do it that way.
Best,
~DD
