Call external lisp within a lisp of a DCL
sam_safinia
Message 1 of 8
sam_safinia
How can I call up to run a external lisp within a DCL lisp?
defun C:test (/ AAA  BBB ccc ddd       ) ;;; BBB is a function in an external lisp
  (setq dcl_id (load_dialog "test.dcl"))
  (if (not (new_dialog "test" dcl_id))
    (progn (alert " Error in loading the dialog (test.dcl) ")
           (exit)
     (action_tile
       "D_AAA"
       "(setq ccc t)(done_dialog)"
     (action_tile
       "D_BBB"
       "(setq ddd t)(done_dialog)"
	(action_tile "cancel" "(done_dialog)")
  (start_dialog)
  (unload_dialog dcl_id)
  (cond
           ((and ccc) (progn (c:AAA)     (C:TEST)))
           ((and ddd) (progn (c:BBB)     (C:TEST))) ;; BBB is external function
  (princ)
DCL
test : dialog {
          label = "Test";
        : button {
            label = "Test1";
            key = "D_AAA";
			is_default = false;
        : button {
            label = "Test2";
            key = "D_BBB";
			is_default = false;
     ok_only ;
I want to assign function BBB to an external lisp to work for button Test2 in attached dcl.
Replies (7)
Message 2 of 8
Moshe-A
hi,
it is more easy than you think...you need to load it in memory before calling it
(cond
   ((/=  ccc nil)
     (load "aaa")
     (c:AAA)
   ((/= ddd nil)
     (load "bbb")
     (c:BBB )
); cond
ofcourse you can check if the load is successful
(load "aaa")
(if (c:aaa)
   (do_run)
   (echo_error_msg)
the (load) function has a second argument [onfailure]  to return if the load fails
if (c:AAA) and (c:BBB) are just a regular functions there is not need to prefix functions name with C:
cheers
moshe
Message 3 of 8
hmsilva
Hi s_plant,
in addition to Moshe-A suggestions, and if I did understood your goal:
do the selected function, AAA or BBB, return to the test.dcl and only exits the loop when the user chooses 'Cancel'.
Perhaps something like this:
(defun c:test (/ ccc ddd)
             (exit)
   (action_tile
      "D_AAA"
   (action_tile
      "D_BBB"
   (start_dialog)
   (cond
      (ccc (c:AAA) (C:TEST))
      (ddd (c:BBB) (C:TEST))
   (princ)
(defun c:AAA nil
   (alert "\n This is AAA function")
(defun c:BBB nil
   (alert "\n This is BBB function")
DCL
test : dialog {
          label = "Test";
        : button {
            label = "Test1";
            key = "D_AAA";
			is_default = false;
        : button {
            label = "Test2";
            key = "D_BBB";
			is_default = false;
     cancel_button ;
Hope this helps,
Henrique
Message 4 of 8
sam_safinia
Thanks Henrique and Mashe. Both suggestions are working.
Is it possible to assign multi function(or in therefore lisps) to only one action tile? I mean by hitting a button several lisp run at once.
Message 5 of 8
hmsilva
You're welcome, s_plant.
Yes, in your code, you are calling two functions per button:
(cond
you can add functions as needed:
(cond
      (ccc (c:AAA) (DDD) (C:EEE) (C:TEST))
      (ddd (c:BBB) (ETC) (C:TEST))
Henrique
Message 6 of 8
Moshe-A
when you hit a dcl button you can run as many lisps files/functions as you like by just calling them in a row
Message 7 of 8
sam_safinia
I tried your suggestions but did not get it right. To be specific,
how can I assign this lisp to second button "Test2" considering following cases?
case 1: when it is an external lisp (or vlx)
case 2 : when we can accommodate it within our main lisp "Test"
(defun c:DELDIM (/ ss)
  (setq ss (ssget "x" (list (cons 0 "Dimension"))))
  (if ss
    (vl-cmdf ".erase" ss "")
    (princ "\nNo dimensions in this drawing!")
  (princ)
Message 8 of 8
sam_safinia
It's fixed by removing brackets as:
(cond
      (ccc (c:AAA) fff (C:EEE) (C:TEST)) ;; No bracket need for setq it was (fff)
 Thanks guys
