bypass error when using vla-get-name
GeryKnee
GeryKnee
I wrote the following
(defun Fn ( Obj / *error* RES)
(defun *error* (errmsg)
(PRINC)
(princ "FnSTART")
(Setq RES (vla-get-name Obj))
(princ ">FnEND")
RES
(defun c:cm nil
(princ "In")
(Fn nil)
(princ ">Out")
After a call to cm command i get :
In>FnSTART
I expepted :
In>FnSTART>FnEND>Out
That's because after error caused by passing a nil Obj value to Fn , the code doesn't continous bypassing the error.
How this could be done?
Sincerely,
Gery
komondormrex
hey,
that way
(defun Fn ( Obj / RES)
	(princ "FnSTART>")
	(Setq RES (vl-catch-all-apply 'vla-get-name (list Obj)))
	(princ "FnEND>")
	RES
(defun c:cm nil
	(princ "In>")
	(Fn nil)
	(princ "Out")
	(princ)
GeryKnee
Thank you very match for your hlp komondormrex
Sincearly,
Gery
komondormrex
your welcome)
ВeekeeCZ
Well, vl-catch-all-apply might prevent the code from falling into error, but if it fails, it returns the name of the error.
So, it is better to add vl-catch-all-error-p to determine whether the result is ok or it's the error..
(defun Fn ( Obj / RES)  ;; returns either name or nil if failed
  (if (not (vl-catch-all-error-p (Setq RES (vl-catch-all-apply 'vla-get-name (list Obj)))))
    RES)
(defun c:cm nil
  (princ "In>")
  (if (setq name (Fn nil))
    (you are good to go)
    (get-name faild, so do somthing about it))
  (princ "Out")
  (princ)
