Burst all blocks in a drawing (without selection set)
sam_safinia
Message 1 of 14
sam_safinia
I am using this super lisp By Lee Mac for a while (thanks you exist Lee!) but wondering how it can be rectify in a way that it burst every single blocks in a drawing and with no selection window(set). How can put all existing blocks in its list? Thanks
Replies (13)
Message 2 of 14
hmsilva
Hi s_plant,
ensures that 'BurstUpgradedV1-2.lsp' is loaded, and something like this should do the trick
(defun c:demo (/ ss )
   (if (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1))))
      (LM:burst ss)
   (princ)
Hope this helps,
Henrique
Message 3 of 14
sam_safinia
Henrique,
You rock!
Is there any way to combine both lisps into one rather than to load them separately? Thanks
Message 4 of 14
hmsilva
You're welcome, s_plant
add the 'demo' function at the end of the main code...
Henrique
Message 5 of 14
sam_safinia
i added but the main lisp does not function properly as before. It only burst some of the blocks!! I have not checked properly before but even with previous method I got same result as partially bursting.
Message 6 of 14
hmsilva
I'm confused...
Let's recap, if you add the 'demo' function, after the Lee Mac's BurstUpgradedV1-2.LSP end, after 'End of File ', you'll have the original 'iburst' command, and the 'demo' command.
 If you type 'iburst' the code will ask to select blocks, if you type 'demo' no selection will be asked, and all blocks with attributes will be burst...
Henrique
Message 7 of 14
sam_safinia
Yes, That's correct. Please find attached files o sample drawing and modified lisp.
Message 8 of 14
hmsilva
Hi s_plant,
just remove the (66 . 1) from the 'demo' function, It should work as expected.
Henrique
Message 9 of 14
sam_safinia
Thanks Henrique. Work Perfectly
Message 10 of 14
hmsilva
You're welcome, s_plant!
Henrique
Message 11 of 14
sam_safinia
I tested the original lisp (same result with lisp without  selection prompt) and it will burst all block within my drawing after 4th attempts! It means that I need to run the lisp few times to get the job done. Is there any way to run any lisp several times?
   (if (setq ss (ssget "_X" '((0 . "INSERT") )))
      (LM:burst ss)
      ;; Here I need looping back to the top and re-running
   (princ)
Message 12 of 14
hmsilva
      (LM:burst ss)
   (princ)
Hi s_plant,
the 'repeat' function...
We could use the 'while' function, but if they exist non-uniformly scaled blocks or xrefs, the the loop would be endless...
(defun c:demo (/ ss)
   (repeat 4
      (if (setq ss (ssget "_X" '((0 . "INSERT"))))
         (LM:burst ss)
   (princ)
Hope this helps,
Henrique
Message 13 of 14
This doesn't work anymore with Lee's latest script. Its version 1.7
@hmsilva Do you think you can update your script to work with Lee's latest script?
Message 14 of 14
dlanorh
It was designed to work with the attached.
I am not one of the robots you're looking for
