Burst all blocks in a drawing (without selection set)
sam_safinia
3,568件の閲覧回数
13件の返信
メッセージ1/14
sam_safinia
I am using this super lisp By Lee Mac for a while (thanks you exist Lee!) but wondering how it can be rectify in a way that it burst every single blocks in a drawing and with no selection window(set). How can put all existing blocks in its list? Thanks
0 件のいいね
3,569件の閲覧回数
13件の返信
返信 (13)
メッセージ2/14
hmsilva
Hi s_plant,
ensures that 'BurstUpgradedV1-2.lsp' is loaded, and something like this should do the trick
(defun c:demo (/ ss )
   (if (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1))))
      (LM:burst ss)
   (princ)
Hope this helps,
Henrique
0 件のいいね
メッセージ3/14
sam_safinia
Henrique,
You rock!
Is there any way to combine both lisps into one rather than to load them separately? Thanks
0 件のいいね
メッセージ4/14
hmsilva
You're welcome, s_plant
add the 'demo' function at the end of the main code...
Henrique
0 件のいいね
メッセージ5/14
sam_safinia
i added but the main lisp does not function properly as before. It only burst some of the blocks!! I have not checked properly before but even with previous method I got same result as partially bursting.
0 件のいいね
メッセージ6/14
hmsilva
I'm confused...
Let's recap, if you add the 'demo' function, after the Lee Mac's BurstUpgradedV1-2.LSP end, after 'End of File ', you'll have the original 'iburst' command, and the 'demo' command.
 If you type 'iburst' the code will ask to select blocks, if you type 'demo' no selection will be asked, and all blocks with attributes will be burst...
Henrique
0 件のいいね
メッセージ7/14
sam_safinia
Yes, That's correct. Please find attached files o sample drawing and modified lisp.
0 件のいいね
メッセージ8/14
hmsilva
Hi s_plant,
just remove the (66 . 1) from the 'demo' function, It should work as expected.
Henrique
0 件のいいね
メッセージ9/14
sam_safinia
Thanks Henrique. Work Perfectly
0 件のいいね
メッセージ10/14
hmsilva
You're welcome, s_plant!
Henrique
0 件のいいね
メッセージ11/14
sam_safinia
I tested the original lisp (same result with lisp without  selection prompt) and it will burst all block within my drawing after 4th attempts! It means that I need to run the lisp few times to get the job done. Is there any way to run any lisp several times?
   (if (setq ss (ssget "_X" '((0 . "INSERT") )))
      (LM:burst ss)
      ;; Here I need looping back to the top and re-running
   (princ)
0 件のいいね
メッセージ12/14
hmsilva
      (LM:burst ss)
   (princ)
Hi s_plant,
the 'repeat' function...
We could use the 'while' function, but if they exist non-uniformly scaled blocks or xrefs, the the loop would be endless...
(defun c:demo (/ ss)
   (repeat 4
      (if (setq ss (ssget "_X" '((0 . "INSERT"))))
         (LM:burst ss)
   (princ)
Hope this helps,
Henrique
0 件のいいね
メッセージ13/14
適用対象外
This doesn't work anymore with Lee's latest script. Its version 1.7
@hmsilva Do you think you can update your script to work with Lee's latest script?
0 件のいいね
メッセージ14/14
dlanorh
It was designed to work with the attached.
I am not one of the robots you're looking for
0 件のいいね
