browse for xref from current directory
robert06
Message 1 of 9
robert06
I'd like xref command to open current drawing folder window to browse for attaching xref, by default it opens a directory used previous time for adding a xref.
(command "-xref" "o" |open current drawing location window for browsing| "0,0,0" "1" "1" "0")
Thanks!
  • xref
Replies (8)
Message 2 of 9
ВeekeeCZ
HERE is a similar example.
Message 3 of 9
Kent1Cooper
Here is what I use to open a Drawing in the Current Folder:
;;;  DwgCurrentFolder.lsp
;;;  to open a Drawing in the Current drawing's Folder
(defun C:DCF ()
  (vla-activate
    (vla-open
      (vla-get-documents
        (vlax-get-acad-object)
      (getfiled "Select drawing:" (getvar 'dwgprefix) "dwg" 0)
(prompt "\nType DCF to open a Drawing in the Current Folder.")
Can you modify that for your purpose?
Kent Cooper, AIA
Message 4 of 9
robert06
Nice & easy, this works fine, thanks:
(command "-xref" "o" (getfiled "Select drawing:" (getvar 'dwgprefix) "dwg" 0) "0,0,0" "1" "1" "0")
I wonder if there is a way to make the getfield window scaleable like a regular file browser window?
Message 5 of 9
robert06
Sorry i could not make use of the method using registry values and windows profile data.
Message 6 of 9
robert06
Still, it gave a clue, thanks! Here's an useful option to set all default paths by 'dwgprefix
https://www.cadtutor.net/forum/topic/67098-open-and-saveas-default-path/
Message 7 of 9
ronjonp
@robert06 Figured out what key was missing. I've updated the code @ CadTutor.
;; ;; RJP » 2022-01-05 -XREF dialog key
			("Select Reference File" "InitialDirectory")
Message 8 of 9
robert06
thank you to @ronjonp for further improvements at the link
Message 9 of 9
ronjonp
@robert06 @ You're welcome👍
