Boundry lisp
Boundry lisp
Message 1 of 8
Boundry lisp
Hi eveyone,
I want to use the boundry command but when I click on it, I don't want to get the window that asks for "pick points" etc.
I want to save clicks on the mouse by using the command I want to get the cursor state to pick the internal boundry of lines.
Thank you
Replies (7)
Message 2 of 8
ВeekeeCZ
How about use the command line version of the boundary command
-BOUNDARY
Note the dash.
Message 3 of 8
Kent1Cooper
By "get the cursor state," do you mean that you want to take the current location of the cursor as a pick in an enclosed area, without actually picking?  Would you position the cursor first, and then type in a command name [since if that's the idea, you couldn't pick some menu item]?
Kent Cooper, AIA
Message 4 of 8
Hi BeekeeCZ
It is still wasting clicks , I will explain:
I want by picking the internal side of a closed area I will get the polygon , without any other questions.( like if I want to keep the polygon or not)
by this I want to make polygons from a closed area just by click on the command  "boundry"  and then click on closed areas as much as I want and it will produce the boundries.
It is exactly like the boundry command but without the windows that ask for (pick a point) , or if I want to keep the polygon,
Hope that I was clear enough this time.
Thank you all
Message 5 of 8
ВeekeeCZ
Sorry, I can't replicate this behavior on C3D 2016. If I run the -BOUNDARY command, it asks for a point and that's it. No other question. It does not maintain any current polygon...
I'm probably missing something - or are you using some vertical? By "polygon" do you mean the actual entity type "polygon"?
Maybe some else would know...
Message 6 of 8
Kent1Cooper
@Anonymous wrote:
.... I want to make polygons from a closed area just by click on the command  "boundry"  and then click on closed areas as much as I want and it will produce the boundries.
Try this [in simplest terms, minimally tested]:
(defun C:B1 (/ pt)
  (while (setq pt (getpoint "\nPick in closed area: "))
    (command "_.boundary" pt "")
[And note that there's an A in BoundAry.]
You could UNDEFINE the original Boundary command, and then define a new one with the above using C:BOUNDARY in place of C:B1, if you virtually always want to use it in this way every time you call for the command, whether by typing in the name or an alias or picking a menu item.  You would still have the native command available for any time you need it, by typing it in with the period/decimal prefix.
Kent Cooper, AIA
Message 7 of 8
Thank you very much!!!  Kent1Cooper
Exactly what I wanted!
Message 8 of 8
john.uhden
Thank you for the spelling lesson.  I was wondering if he was referring to a new "Foundry" command for maybe casting entities into 3D objects.  What's the melting point of a spline?  Does it depend on thickness?
John F. Uhden
