Blocktoxref in multi file ?
Message 1 of 14
Hi all,
I have a problem with a thousand dwg binded (not my draw). Now i mean use command "Blocktoxref". Do anyone have the way with multi file in multi folder Categories than one by one open dwg and use Blocktoxref" in express ?
Thanks for solution.
Replies (13)
Message 2 of 14
danglar
Hi
Try this one.. it can halp you for binded xrefs
Message 3 of 14
HI apelbaum2014,
Thanks for repply.
your list not exactly what i mean.
I thinhk i need script or DBX for delete blk "test" in dwg then attach xref "test" to dwg.
If use script then file large size open long time. So i mean use DBX.
Can show me some example for DBX for xref attach ?
Message 4 of 14
Okey,
i like this "silence". So i must Thinking.
Then i found some code del_block and attachXref of Lee Macto fill lisp.
Here code attachxref:
;xref is str "D:\\Desktop\\Temp\\Xref.dwg"
;list_obj is (list X Y Z rotate) of blk
(defun attachxref_PS (doc xref list_obj / )
(vla-attachexternalreference (vla-get-paperspace doc) master
(vl-filename-base xref)
(vlax-3d-point '(0 0 0))
(car list_obj);1.
(cadr list_obj);1.
(caddr list_obj);1.
(cadddr list_obj);0.
:vlax-true
So i have a question: how can attach xref to PS when drawing active model space ? although i get PS to attach xref.
Thanks in advance.
Message 5 of 14
Ahhh,
fixed done.
^_^
Message 6 of 14
danglar
Hi
The first part of your problem can solve attached lisp (I mean to delete block from dwg and also from database of drawing)
I hope it's help you
Message 7 of 14
danglar
.. and for second part of your problem you can use this function (see attached dll)
^P^C(command "netload" "AutoWblock.dll") AutoWblock
Message 8 of 14
Hi apelbaum2014
you right,
so i change code to:
(LM:odbx '(lambda ( doc ) (LM:deleteblocks doc (list name))) lst t)
Thank you.
^_^
Message 9 of 14
Okey, but
Can your code call via ODBX ? because i mean write to multi drawing and i remember can not call command.
Message 10 of 14
danglar
.. in order to  write  it to multi drawing  use this code:
(defun C:exv ( / COUNT DIR FILENAME FILES SCRIPTNAME) ;works only with igal.lsp
 (if (setq dir (getfiled "Select the drawing directory:" "" "dwg" 0))
 (setq dir (vl-filename-directory dir))
 (if dir
 (setq files (vl-directory-files dir "*.dwg" 1))
 (if files
 (progn
 (setq scriptname (open "C:\\batch.scr" "w")
 count 0
 (while (setq filename (nth count files))
 (setq filename (strcat dir "\\" filename))
 (write-line (strcat "_open \"" filename "\"") scriptname)
 ;(write-line "_zoom extents" scriptname)
 ;(write-line "_DWG-PURGE" scriptname)
 (write-line "zx" scriptname) ;;; HERE YOU CAN ATTACH YOUR FUNCTION!
 (write-line "_qsave" scriptname)
 (write-line "_close" scriptname)
 (setq count (1+ count))
 (close scriptname)
 (princ)
(c:exv)
(command "script" "C:\\batch.scr")
Message 11 of 14
Okey
I knew use script. But sometime error open file readonly and i checked have not anyone or other pc open it in server. Only my pc open. Can u point me ? Or fix this.
Thank u so much.
Message 12 of 14
danglar
it's curious, but this code working perfect for me..
anyway try to load your function to starup suite and than use only alias of it whithout loading lisp function at all
Message 13 of 14
Yep, i must use 2 way: script and DBX to know.
In some case use script faster, and some case lower DBX then i custome it. ^_^
Anyway, thank you so much for share. 😄
Heizzzz, okey, pause lisp, time-out.
Now time for thesis of Master.
Message 14 of 14
Hello Pony,
Can you please share the working version of the lisp routine that unbound xrefs and can run on multiple drawings.
Thank you,
Nasr
