Blocks to multiple point LISP
mathew.grainger
Observer Observer
mathew.grainger
Observer
Observer
Would somebody be kind enough to help me, i'm having trouble with a LISP file.
I am trying to insert the same block to multiple points, all at once.
i have got my hands on the following;
(defun C:PT2BLK ( / ss blk n) (setq ss (ssget "x" '((0 . "POINT"))) blk (getstring "\nName of Block: ") )::setq (if (and ss (tblsearch "block" blk)) (progn (setq n (1- (sslength ss))) (while (>= n 0) (setq pt (cdr (assoc 10 (entget (ssname ss n)))) n (1- n) );; setq (command "_.-insert" blk pt "" "" "") );;while );;progn );; if (princ) )
However, when i load this file into CAD it flags up an error message.
; error: malformed list on input
Thanks you.
ВeekeeCZ
Don't do this line structure... its really hard to read and control.
If so, remove all the commentary.
In one case you have :: instead of ;;
That's all, otherwise the code works. You should turn the OSNAPs off as well. Also you can add T for getstring that allows you to type a block name with spaces.
        );;setq
  (if (and ss
    (progn
      (while (>= n 0)
              n (1- n) );; setq
        (command "_.-insert" blk "_none" pt "" "" "")
        );;while
      );;progn
    );; if
  (princ) )
I usually would do something like this:
  (if (and (setq ss (ssget "x" '((0 . "POINT"))))
           (setq blk (getstring T "\nName of Block: "))
           (or (tblsearch "block" blk)
               (prompt (strcat "\nBlock '" blk "' is not defined in the drawing!"))
    (repeat (setq n (sslength ss))
               "_s" 1
               "_r" 0
               "_none" (cdr (assoc 10 (entget (ssname ss (setq n (1- n)))))))))
  (princ)
mathew.grainger
Observer
Observer
Wow, thank you for your help and quick response. You have saved me alot of time.
sthompson1021
Would it be possible to use this lisp and insert a block to points that are on one layer and a different block to points on a different layer?
cadffm
remove the three chars "x" in ssget row,
Now, you can select the points you want.
Sebastian
sthompson1021
OK, I have to plead my ignorance. What are you referring to when you say "three chars"
sthompson1021
Never mind, I figured it out.  Thanks for the help. It worked perfect.
