Block selection (with window method)
k005
Advisor Advisor
Message 1 of 19
k005
Hello everyone
How can we make a selection in the Window by entering the layer names of the blocks?
sample:
BLOCK REFERENCE
Beam ... (layer)
Colon...(layer)
Panel...(layer)
1- First of all, region selection. ( ssget window )
2- I will enter these names at the beginning with getstring t.
or let me select one by one with the mouse.. (Beam-Column-Panel....+ )
Thanks in advance to the helper.
Replies (18)
Message 2 of 19
ВeekeeCZ
You still don't know anything? Gees.
Message 3 of 19
k005
I didn't have a study like learning lisp. Isn't this already clear?
Message 4 of 19
ВeekeeCZ
That's just a silly excuse. It's hard to imagine someone here who studied a field that included learning of LISP. My guess would be - no one. Some may have some programming basics, but that's about it. Anyway, LISP is designed so that its basics are really simple and can be mastered by anyone educatable.
But as it seems, you only studied how to abuse people. That's clear to me but might not to you.
Message 5 of 19
k005
why would it be stupid?
So I have to learn lisp to ask questions in this forum?
* Also in my opinion do not abuse people. There are applications for those who want to help...
you cannot help. no problem.
Message 6 of 19
ВeekeeCZ
You're abusing goodwill.
And use the right words. You are not asking questions, you're asking people to WRITE THE CODE FOR YOU.
Message 7 of 19
k005
I am using the right words.
Yes, I'm asking questions to help them. If this is not suitable for you, you will not write an answer.
Why did you drag this subject so long?
Message 8 of 19
k005
* Question is up to date...
Message 9 of 19
Sea-Haven
You can select blocks by name "Beam,Column,Slab" then look at each item in ssget and delete those with wrong layer matching block name. Or you need to build a big filter using the "(-4" in the filter code including, and's, or's very complicated so no answer from me.
Message 10 of 19
Kent1Cooper
To find Blocks named "1" on Layer "1" and Blocks named "2" on Layer "2" and Blocks named "3" on Layer "3":
(setq YourVariableName
  (ssget "_X"
      (-4 . "<OR")
        (-4 . "<AND") (2 . "1") (8 . "1") (-4 . "AND>")
        (-4 . "<AND") (2 . "2") (8 . "2") (-4 . "AND>")
        (-4 . "<AND") (2 . "3") (8 . "3") (-4 . "AND>")
      (-4 . "OR>")
Help is not very helpful in helping you find information about these, but you can read about "Logical Grouping of Selection Filter Tests>here<.
Kent Cooper, AIA
Message 11 of 19
k005
The next step is to take the layer name of the object selected with the mouse and add it to the code.
Thank you so much. @Kent1Cooper
(Defun C:bsec()
(setq pn1 (getpoint "\nÜst köşe?"))
(setq pn2 (getcorner pn1 "\nAlt köşe?"))
(setq bloklar
 ; (ssget "_X"
(ssget "W" pn1 pn2
      (-4 . "<OR")
        (-4 . "<AND") (8 . "Kolon") (-4 . "AND>")
        (-4 . "<AND") (8 . "Kiriş") (-4 . "AND>")
        (-4 . "<AND") (8 . "Panel") (-4 . "AND>")
      (-4 . "OR>")
(sssetfirst bloklar))
Message 12 of 19
Kent1Cooper
Your AND wrappers with only one entry between them are kind of pointless, are they not?  Did you mean to include another entry, whether with a specific Block name as in my previous suggestion, or just to limit it to Blocks?
        (-4 . "<AND") (0 . "INSERT") (8 . "Kolon") (-4 . "AND>")
        (-4 . "<AND") (0 . "INSERT") (8 . "Kiriş") (-4 . "AND>")
        (-4 . "<AND") (0 . "INSERT") (8 . "Panel") (-4 . "AND>")
Even that -- finding all Blocks on those Layers without limiting to certain Block names -- could be done without the AND wrappers:
(ssget "W" pn1 pn2 '((0 . "INSERT") (8 . "Kolon,Kiriş,Panel")))
As you have it, the same could be done with just this:
(ssget "W" pn1 pn2 '((8 . "Kolon,Kiriş,Panel")))
Kent Cooper, AIA
Message 13 of 19
k005
Yes, there may be other layers besides these three layers. Or it can be only 1 layer.
For now, I want to collect 5 layers in 5 different variables for noses.
so I will create a loop and get the layer names or names... with the mouse.
When I exit the loop, the layer to be selected will take a null value.
my variables.
layer1
layer2
layer3
layer4
layer5
is in the form.
Column, beam, panel was an example.
layer1=column
layer2=beam
layer3=panel
layer4=""
layer5=""
I want to do something like this...
* should not click on an empty spot and exit the command.
Message 14 of 19
Sea-Haven
You can select select select getting layer names, and joins as a string "layer1,layer2,layer3" note the "," between.
(ssget "W" pn1 pn2 (list (cons 8 str)))
Message 15 of 19
k005
OK.
But ; The str variable must come from a loop. and by selecting it with the mouse...
because the number of layers to be selected is not clear... It can be 1, 5, 7...
Message 16 of 19
Sea-Haven
That is what I said pick pick pick as many as required and make the layer list for the ssget filter.
(setq lay (cdr (assoc 8 (entget (car (entsel "pick object ")))))) then strcat together.
Message 17 of 19
k005
(setq str (cdr (assoc 8 (entget (car (entsel "Obje seç"))))))
I added the code. But it only selects 1 object.
How do I make multiple selection?
and when you click on the space, the command exits. should not come out.
Thank you.
Message 18 of 19
Sea-Haven
You skipped over the (setq lay (strcat lay "," newlay) )
(setq lay (cdr (assoc 8 (entget (car (entsel "\nPick object for layer"))))))
(while(setq ent (entsel "\nPick object for layer"))
(setq lay (strcat lay "," (cdr (assoc 8 (entget (car ent))))))
Message 19 of 19
k005
@Sea-Haven
Thank you.
